주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 9 Pro Charging Port Replacement
필요한 것
  1. OnePlus 9 Pro Charging Port Replacement, Rear Glass: 1 단계, 이미지 1개 중 1개
    • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Unplug any chargers/peripheries and power off your phone.
  2. OnePlus 9 Pro Charging Port Replacement: 2 단계, 이미지 1개 중 1개
  3. OnePlus 9 Pro Charging Port Replacement: 3 단계, 이미지 2개 중 1개 OnePlus 9 Pro Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Use a hair dryer to lightly heat the perimeter of the rear glass.
    • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
    • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
  4. OnePlus 9 Pro Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Apply a suction handle as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  5. OnePlus 9 Pro Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
    • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
  6. OnePlus 9 Pro Charging Port Replacement: 6 단계, 이미지 2개 중 1개 OnePlus 9 Pro Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift the rear glass up and off of the phone.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  7. OnePlus 9 Pro Charging Port Replacement, Bottom Loudspeaker: 7 단계, 이미지 2개 중 1개 OnePlus 9 Pro Charging Port Replacement, Bottom Loudspeaker: 7 단계, 이미지 2개 중 2개
    • Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
  8. OnePlus 9 Pro Charging Port Replacement: 8 단계, 이미지 3개 중 1개 OnePlus 9 Pro Charging Port Replacement: 8 단계, 이미지 3개 중 2개 OnePlus 9 Pro Charging Port Replacement: 8 단계, 이미지 3개 중 3개
    • Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
    • Use an opening pick to remove the flash module by the camera.
    • Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
    • Use an opening pick to pry off the motherboard cover.
  9. OnePlus 9 Pro Charging Port Replacement: 9 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove five screws that secure the lower daughterboard cover.
    • Two of the screws have a white head and are 4.8 mm-long. They go in the bottom right corner of the daughter and mother board.
    • The other three screws are black and are also 4.8 mm-long.
  10. OnePlus 9 Pro Charging Port Replacement: 10 단계, 이미지 2개 중 1개 OnePlus 9 Pro Charging Port Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the two interconnect cables by inserting a spudger under each lip and prying straight up.
  11. OnePlus 9 Pro Charging Port Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three screws from the loudspeaker using a Phillips #000 screwdriver.
  12. OnePlus 9 Pro Charging Port Replacement: 12 단계, 이미지 1개 중 1개
    • Use the spudger to pry up and remove the loudspeaker.
  13. OnePlus 9 Pro Charging Port Replacement, Charging Port: 13 단계, 이미지 3개 중 1개 OnePlus 9 Pro Charging Port Replacement, Charging Port: 13 단계, 이미지 3개 중 2개 OnePlus 9 Pro Charging Port Replacement, Charging Port: 13 단계, 이미지 3개 중 3개
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  14. OnePlus 9 Pro Charging Port Replacement: 14 단계, 이미지 1개 중 1개
    • Insert a spudger under the lip of the charging port press connector and pry it straight up to disconnect it.
  15. OnePlus 9 Pro Charging Port Replacement: 15 단계, 이미지 3개 중 1개 OnePlus 9 Pro Charging Port Replacement: 15 단계, 이미지 3개 중 2개 OnePlus 9 Pro Charging Port Replacement: 15 단계, 이미지 3개 중 3개
    • Unclip the ribbon cable on bottom left side of the daughter board, using the spudger.
    • Insert a spudger under the lip of the upper-left interconnect cable press connector and pry it straight up to disconnect it.
  16. OnePlus 9 Pro Charging Port Replacement: 16 단계, 이미지 1개 중 1개
    • Use a spudger to pry the coaxial network cables straight up to disconnect them.
    • Everything should be fully disconnected from the daughterboard.
  17. OnePlus 9 Pro Charging Port Replacement: 17 단계, 이미지 1개 중 1개
    • Pry out the daughter board out from the top using the spudger.
  18. OnePlus 9 Pro Charging Port Replacement: 18 단계, 이미지 2개 중 1개 OnePlus 9 Pro Charging Port Replacement: 18 단계, 이미지 2개 중 2개
    • Pry off the USB charging port and the ribbon cable with the spudger by prying it on the right side.
    • Remove the charging port.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brayan Santana
회원 가입일: 02/19/25
777 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 106
전체 시간: 1,229
