주요 콘텐츠로 건너뛰기
OnePlus 9 Pro Rear Glass Replacement
필요한 것
  1. OnePlus 9 Pro Rear Glass Replacement, Rear Glass: 1 단계, 이미지 1개 중 1개
    • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Unplug any chargers/peripheries and power off your phone.
  2. OnePlus 9 Pro Rear Glass Replacement: 2 단계, 이미지 1개 중 1개
  3. OnePlus 9 Pro Rear Glass Replacement: 3 단계, 이미지 2개 중 1개 OnePlus 9 Pro Rear Glass Replacement: 3 단계, 이미지 2개 중 2개
    • Use a hair dryer to lightly heat the perimeter of the rear glass.
    • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
    • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
  4. OnePlus 9 Pro Rear Glass Replacement: 4 단계, 이미지 1개 중 1개
    • Apply a suction handle as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  5. OnePlus 9 Pro Rear Glass Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
    • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
  6. OnePlus 9 Pro Rear Glass Replacement: 6 단계, 이미지 2개 중 1개 OnePlus 9 Pro Rear Glass Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift the rear glass up and off of the phone.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
2다른 기여자 명과 함께
Averie
회원 가입일: 02/17/25
273 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 27
지난 30일: 85
전체 시간: 643
