주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus Nord N20 5G Screen Replacement
필요한 것
    1. OnePlus Nord N20 5G Screen Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Insert the SIM ejection tool or a spudger in the small hole next to the SIM tray.
      • Push it gently until the tray pops out.
      • Remove the SIM card tray by sliding it outwards.
      댓글 쓰기
    2. OnePlus Nord N20 5G Screen Replacement: 2 단계, 이미지 2개 중 1개 OnePlus Nord N20 5G Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Heat the iOpener in a microwave for about 30 seconds. If the iOpener isn’t hot enough, reheat it for another 10-30 seconds.
      • Apply the heated iOpener on the backside of the phone for a minute to loosen the adhesive.
      • Use the iFixit opening tool and slide it along the edges of the phone to pry the back panel off.
      댓글 쓰기
    1. OnePlus Nord N20 5G Screen Replacement, Screen: 3 단계, 이미지 1개 중 1개
      • Remove the 18 3.9 mm screws using a Phillips #0 screwdriver.
      댓글 쓰기
    2. OnePlus Nord N20 5G Screen Replacement: 4 단계, 이미지 2개 중 1개 OnePlus Nord N20 5G Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Take the iFixit opening tool and run it along the edges.
      • Separate the back housing from the frame of the screen.
      댓글 쓰기
    3. OnePlus Nord N20 5G Screen Replacement: 5 단계, 이미지 2개 중 1개 OnePlus Nord N20 5G Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Disconnect the brackets attached to the motherboard using a spudger.
      댓글 쓰기
    4. OnePlus Nord N20 5G Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Disconnect the bracket attached to the daughterboard using a spudger.
      댓글 쓰기
    5. OnePlus Nord N20 5G Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the battery.
      • This step is to ensure the heat from the iOpener does not damage the phone's battery.
      댓글 쓰기
    6. OnePlus Nord N20 5G Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Heat up an iOpener for 30 seconds.
      • Place it on the front of the screen until you are able to slide a Jimmy in between the screen and the phone.
      • Make sure you do not overheat the screen or camera as it might damage the camera lens.
      댓글 쓰기
    7. OnePlus Nord N20 5G Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Attach a suction handle to the screen.
      • Avoid being too rough to prevent more damage.
      댓글 쓰기
    8. OnePlus Nord N20 5G Screen Replacement: 10 단계, 이미지 2개 중 1개 OnePlus Nord N20 5G Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Use a suction tool to pull the screen while prying the screen with a Jimmy.
      • The glue around the edges may need to be warmed up multiple times.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mayson Solis
회원 가입일: 06/21/21
205 평판
안내서 1개를 작성함
2가이드 댓글
Mayson, Thank you for that clear set of instructions. I am trying to perform a Screen Replacement on what I believe is a OnePlus Nord N20 5G Phone. But, when open, it does not look quite like the one in this or any repair instructional site/page I've gone to. My broken screen is now attached only by its flimsy cable, which seems to go in and in between the front and the center section and connects under the daughter card or remove any modular parts, to get to the connection. The battery looks the same but doesn't have that handy disconnect for its cable. That seems to attach under that same card. Do you have any suggestions for me? (Please?)
-Chris C
Chris Cooney - 답글 공유
Why did you change to a single lens phone? The rest of this is no help.
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 112
전체 시간: 1,836
