주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus Nord Screen Replacement
필요한 것
  1. OnePlus Nord Screen Replacement, Loosen the rear glass adhesive: 1 단계, 이미지 1개 중 1개
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. If you have a heatbed with precise temperature control (like any FDM 3D printer with heatbed) 45°C is enough. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  2. OnePlus Nord Screen Replacement, Create a gap: 2 단계, 이미지 2개 중 1개 OnePlus Nord Screen Replacement, Create a gap: 2 단계, 이미지 2개 중 2개
    • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert an opening pick into the gap.
    댓글 쓰기
  3. OnePlus Nord Screen Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 1개 OnePlus Nord Screen Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 2개
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during this process.
    댓글 쓰기
  4. OnePlus Nord Screen Replacement: 4 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement: 4 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a second opening pick under the bottom right corner.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
    댓글 쓰기
  5. OnePlus Nord Screen Replacement: 5 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement: 5 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Insert a third opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the edge of the phone to the top left corner to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    댓글 쓰기
  6. OnePlus Nord Screen Replacement: 6 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement: 6 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Insert a fourth opening pick under the top left corner.
    • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
    댓글 쓰기
  7. OnePlus Nord Screen Replacement: 7 단계, 이미지 2개 중 1개 OnePlus Nord Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick under the bottom left corner.
    • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
    댓글 쓰기
  8. OnePlus Nord Screen Replacement, Remove the back cover: 8 단계, 이미지 1개 중 1개
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    댓글 쓰기
  9. OnePlus Nord Screen Replacement, Remove the motherboard cover: 9 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the ten 3.6 mm-long screws from the motherboard cover.
    댓글 쓰기
  10. OnePlus Nord Screen Replacement: 10 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement: 10 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick under the motherboard cover.
    • Use the opening pick to lift the motherboard cover up and release the plastic clips that holds the cover in its place.
    • Remove the motherboard cover.
    댓글 쓰기
  11. OnePlus Nord Screen Replacement, Disconnect the battery: 11 단계, 이미지 2개 중 1개 OnePlus Nord Screen Replacement, Disconnect the battery: 11 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
    댓글 쓰기
  12. OnePlus Nord Screen Replacement, Remove the daughterboard cover: 12 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the seven 3.6 mm-long screws.
    댓글 쓰기
  13. OnePlus Nord Screen Replacement: 13 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement: 13 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick under the daughterboard cover.
    • Pry up to release the clips holding the daughterboard cover in place.
    • Remove the daughterboard cover.
    댓글 쓰기
  14. OnePlus Nord Screen Replacement, Disconnect the display connector: 14 단계, 이미지 2개 중 1개 OnePlus Nord Screen Replacement, Disconnect the display connector: 14 단계, 이미지 2개 중 2개
    • Use the flat edge of a spudger to pry up and disconnect the display connector from its daughterboard socket.
    댓글 쓰기
  15. OnePlus Nord Screen Replacement, Apply a heated iOpener: 15 단계, 이미지 1개 중 1개
    • Apply a Heat an iOpener to the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  16. OnePlus Nord Screen Replacement, Create a gap: 16 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement, Create a gap: 16 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement, Create a gap: 16 단계, 이미지 3개 중 3개
    • Apply a suction cup to the right edge of the display.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull up the suction cup with strong, steady force to create a gap.
    • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
    댓글 쓰기
  17. OnePlus Nord Screen Replacement, Slice the adhesive: 17 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement, Slice the adhesive: 17 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement, Slice the adhesive: 17 단계, 이미지 3개 중 3개
    • Insert a second opening pick at the bottom right corner.
    • Slide the opening pick along the edge to the top right corner of your phone.
    • Leave both opening picks in their place to prevent the adhesive from resealing.
    댓글 쓰기
  18. OnePlus Nord Screen Replacement: 18 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement: 18 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement: 18 단계, 이미지 3개 중 3개
    • Insert a third opening pick under the top right corner.
    • Slide the opening pick along the edge to slice the adhesive.
    댓글 쓰기
  19. OnePlus Nord Screen Replacement: 19 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement: 19 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement: 19 단계, 이미지 3개 중 3개
    • Slide the opening pick along the edge to cut the adhesive.
    • Leave the opening pick in the bottom left corner so prevent the adhesive from resealing.
    댓글 쓰기
  20. OnePlus Nord Screen Replacement: 20 단계, 이미지 2개 중 1개 OnePlus Nord Screen Replacement: 20 단계, 이미지 2개 중 2개
    • Slide it along the bottom edge to cut the remaining adhesive.
    • Do not remove the screen completely yet. The display cable is still threaded through the frame.
    댓글 쓰기
  21. OnePlus Nord Screen Replacement, Remove the display: 21 단계, 이미지 3개 중 1개 OnePlus Nord Screen Replacement, Remove the display: 21 단계, 이미지 3개 중 2개 OnePlus Nord Screen Replacement, Remove the display: 21 단계, 이미지 3개 중 3개
    • Carefully thread the display cable through the frame.
    • Remove the display.
    댓글 쓰기
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
취소: 해당 안내서를 완성하지 않았습니다.
다른 34명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
67,744 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,437개를 작성함
15가이드 댓글
So essentially the greater part of the guide is only necessary because OnePlus decided to have the display connector at the back of the phone rather than at the front under the display? What a poor choice repairability-wise on their side, very disappointing! Otherwise great guide.
Nikola Steffanov - 답글 공유
Hi Nikola, yes, this is troublesome! Indeed, you have to make a few moves until it is possible to remove the display. Unfortunately, there is no easier way.
Adriana Zwink - 답글 공유
Yes!, I had the same problem, I spent all day trying different ways to get out like three pesky screws. :( Any tips from anybody? I scoured the internet for a few hours, tried a few different things already but any help would be much appreciated!
Matt Farel - 답글 공유
Why do guides only show you how to take apart screens and not how to apply a new one?
Tee Jay - 답글 공유
Hi @Tee Jay, to reassemble your OnePlus Nord and install the new screen, follow the steps in this guide in reverse order.
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 149
지난 30일: 740
전체 시간: 87,114
