주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus One Micro USB Port Replacement
필요한 것
  1. OnePlus One Micro USB Port Replacement, Battery: 1 단계, 이미지 3개 중 1개 OnePlus One Micro USB Port Replacement, Battery: 1 단계, 이미지 3개 중 2개 OnePlus One Micro USB Port Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the SIM tray.
    • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
    • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
    • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
    • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
    댓글 쓰기
  2. OnePlus One Micro USB Port Replacement: 2 단계, 이미지 3개 중 1개 OnePlus One Micro USB Port Replacement: 2 단계, 이미지 3개 중 2개 OnePlus One Micro USB Port Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a pair of tweezers, remove the plastic plugs.
    • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
    • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
    댓글 쓰기
  3. OnePlus One Micro USB Port Replacement: 3 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
    댓글 쓰기
  4. OnePlus One Micro USB Port Replacement: 4 단계, 이미지 3개 중 1개 OnePlus One Micro USB Port Replacement: 4 단계, 이미지 3개 중 2개 OnePlus One Micro USB Port Replacement: 4 단계, 이미지 3개 중 3개
    • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
    • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
    • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
    댓글 쓰기
  5. OnePlus One Micro USB Port Replacement: 5 단계, 이미지 3개 중 1개 OnePlus One Micro USB Port Replacement: 5 단계, 이미지 3개 중 2개 OnePlus One Micro USB Port Replacement: 5 단계, 이미지 3개 중 3개
    • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
    • You can disconnect the battery before freeing it to make removal easier.
    댓글 쓰기
  6. OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: 6 단계, 이미지 3개 중 1개 OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: 6 단계, 이미지 3개 중 2개 OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Once the battery has been removed, we shift our attention to the back panel assembly. This piece is held together by six screws. See info note below.
    • Luckily, the OnePlus One was assembled with all of the same size screws save for the one holding down the motherboard. All of these screws are philips 00 and 3.175 mm. in lenght.
    • Using the spudger we pry open the panel assembly and, behold, we have access to the micro usb port. You can also use a blue opening tool if you prefer.
    • Keep in mind that there are two hidden screws. Both are located beneath plastic plugs. Tweezers are an effective tool for removing the plugs.
    댓글 쓰기
  7. OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: 7 단계, 이미지 3개 중 1개 OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: 7 단계, 이미지 3개 중 2개 OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: 7 단계, 이미지 3개 중 3개
    • Now that we have access to the usb port, we use the flat end of or spudger and lift it off of its connector and free it from the daughterboard.
    댓글 쓰기
  8. OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: 8 단계, 이미지 3개 중 1개 OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: 8 단계, 이미지 3개 중 2개 OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: 8 단계, 이미지 3개 중 3개
    • Now it is time to remove the ribbon. You will notice that there is a small strip of black tape keeping us from from completely freeing it. Not to worry. Simply use the spudger to maneuver the tape out of the way.
    • Your micro USB and attached ribbon are now free to be removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 33명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Chad Jackson
회원 가입일: 09/22/14
5,370 평판
안내서 2개를 작성함
USF Tampa, Team 3-3, Brown Fall 2014 USF Tampa, Team 3-3, Brown Fall 2014 회원
USFT-BROWN-F14S3G3
3 회원들
안내서 29개를 작성함
4가이드 댓글
Thanks back up and working should get a few more years out of it
cheers
robert storrs - 답글 공유
Pretty easy, just be really careful when removing battery from glue ;)
Thanks a lot for this guide which is really complete !
Gael Augeat - 답글 공유
I was able to successfully follow these instructions. Pretty sure I damaged the battery during removal though. I intended to replace the battery anyways, so I’m not too worried about it, but it would be nice to to have some technique listed for removing it less destructively.
George Simpson - 답글 공유
For me USB was not charging because it seems that one of the 2 USB plugs above the battery were loose. I did replace the battery already sometime far in the past so this might have been the cause. If you just want to re-plug on the upper side and lift the port on the lower side, you don't even need to remove the battery. Just make sure that all plugs, not just USB, are tight before screwing everything back together.
Thanks a lot for this guide!
Robert Gutjahr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 103
전체 시간: 38,779
