주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus One Rear Facing Camera Replacement
필요한 것
    1. OnePlus One Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 OnePlus One Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 OnePlus One Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Remove the SIM tray.
      • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
      • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
      • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
      • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
      댓글 쓰기
    2. OnePlus One Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 OnePlus One Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 OnePlus One Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Using a pair of tweezers, remove the plastic plugs.
      • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
      • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
      댓글 쓰기
    3. OnePlus One Rear Facing Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
      댓글 쓰기
    4. OnePlus One Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 OnePlus One Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 OnePlus One Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
      • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
      • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
      • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
      댓글 쓰기
    5. OnePlus One Rear Facing Camera Replacement: 5 단계, 이미지 3개 중 1개 OnePlus One Rear Facing Camera Replacement: 5 단계, 이미지 3개 중 2개 OnePlus One Rear Facing Camera Replacement: 5 단계, 이미지 3개 중 3개
      • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
      • You can disconnect the battery before freeing it to make removal easier.
      댓글 쓰기
    1. OnePlus One Rear Facing Camera Replacement, Removal of Ribbons: 6 단계, 이미지 3개 중 1개 OnePlus One Rear Facing Camera Replacement, Removal of Ribbons: 6 단계, 이미지 3개 중 2개 OnePlus One Rear Facing Camera Replacement, Removal of Ribbons: 6 단계, 이미지 3개 중 3개
      • After the battery has been removed, use the spudger to disconnect the remaining ribbons.
      • Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment.
      댓글 쓰기
    2. OnePlus One Rear Facing Camera Replacement, Removal of Motherboard: 7 단계, 이미지 3개 중 1개 OnePlus One Rear Facing Camera Replacement, Removal of Motherboard: 7 단계, 이미지 3개 중 2개 OnePlus One Rear Facing Camera Replacement, Removal of Motherboard: 7 단계, 이미지 3개 중 3개
      • After removal of the ribbons, there is one final screw. Once you have removed this, the motherboard easily pries out with spudger.
      • This is the only screw that differs in size. This screw is a philips 00, 3.00 mm. in length.
      댓글 쓰기
    3. OnePlus One Rear Facing Camera Replacement, Removal of Rear Facing Camera: 8 단계, 이미지 2개 중 1개 OnePlus One Rear Facing Camera Replacement, Removal of Rear Facing Camera: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      $3.99
      • Once the motherboard has been removed simply pry off the rear facing camera with a spudger or angled tweezers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Javier Cruz
회원 가입일: 09/22/14
2,292 평판
안내서 3개를 작성함
USF Tampa, Team 3-3, Brown Fall 2014 USF Tampa, Team 3-3, Brown Fall 2014 회원
USFT-BROWN-F14S3G3
3 회원들
안내서 50개를 작성함
1가이드 댓글
Steps 3 to 6 I believe are unnecessary.
Liam Ong - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 52
전체 시간: 8,177
