주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Opening Philips EP-Models
필요한 것
  1. Opening Philips EP-Models, Philips EP Model Coffee Makers: 1 단계, 이미지 2개 중 1개 Opening Philips EP-Models, Philips EP Model Coffee Makers: 1 단계, 이미지 2개 중 2개
    • Never forget: Unplug the power cord!
    • Remove all attachments, like the water reservoir, the brewing chamber, the bean compartment lid, and the drip tray. Remove all of the coffee beans.
    • Turn the machine around so the back is facing you. Remove the two T10 Torx screws at the bottom edge. Pull out the back at the bottom edge and lift it down.
    • It's important that the parts are readily visible:
    • The motherboard
    • The pump
    • The flow meter
    • The heating element
    댓글 쓰기
  2. Opening Philips EP-Models: 2 단계, 이미지 1개 중 1개
    • Unscrew the three T10 Torx screws in the coffee bean compartment.
    댓글 쓰기
  3. Opening Philips EP-Models: 3 단계, 이미지 3개 중 1개 Opening Philips EP-Models: 3 단계, 이미지 3개 중 2개 Opening Philips EP-Models: 3 단계, 이미지 3개 중 3개
    • Remove all the beans from the opening on the finger guard of the grinder. A T10 Torx screw will become visible.
    • Unscrew the T10 Torx screw from the finger guard.
    • Lift the finger guard up.
    댓글 쓰기
  4. Opening Philips EP-Models: 4 단계, 이미지 2개 중 1개 Opening Philips EP-Models: 4 단계, 이미지 2개 중 2개
    • Slightly lift the top cover up at the back edge.
    • When putting it back together, make sure the grinder control is sitting right.
    댓글 쓰기
  5. Opening Philips EP-Models: 5 단계, 이미지 2개 중 1개 Opening Philips EP-Models: 5 단계, 이미지 2개 중 2개
    • Pull the upper cover out from under the front cover and lay it slightly offset.
    • Remove both of the T10 Torx screws attached to the side covers.
    • You can remove the top cover completely, especially if you must work on the grinder. But, if you want to see the machine functioning later, then lay it back in its original place.
    • Picture 2 shows the grinder, which can now be easily taken off.
    • If you want to repair the grinder: here are the instructions Replacing the Philips ceramic grinder motor and sensor
    댓글 쓰기
  6. Opening Philips EP-Models: 6 단계, 이미지 3개 중 1개 Opening Philips EP-Models: 6 단계, 이미지 3개 중 2개 Opening Philips EP-Models: 6 단계, 이미지 3개 중 3개
    • Both side panels are still screwed to the lower edge of the front. Unscrew both of the T10 Torx screws out from here.
    • Slide both side panels back a bit, and take them out from the bottom edge.
    댓글 쓰기
결론
Complete the steps in reverse order to reassemble your device.
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
335,961 평판
안내서 311개를 작성함
Repair is War on Entropy Repair is War on Entropy 회원
Community
38 회원들
안내서 1,688개를 작성함
8가이드 댓글
Leider stimmt diese Anleitung nicht für alle EP Modelle, ich besitze die Saeco Philips EP5960-10 diese zu öffnen ist eine Katastrophe. Da gibt es keine einzelne Wände, ich muss unbedingt unten an den Stromanschluss, da meine Maschine Plötzlich nicht mehr angeht, eventuell ist da eine Sicherung verbaut. Phillips will 200 € haben, da lege ich 100 drauf dann bekommt man was neues.
Michael Kollek - 답글 공유
Danke für den Hinweis. Diese Modelle gehen auf eine ältere Linie zurück. Vergleiche mit der Saeco Exprelia.
VauWeh - 답글 공유
VauWeh - 답글 공유
Die Saeco Minuto kommt meiner gleich, leider um unten an den Stromanschluss zu kommen, muss man alles ausbauen, was ein Mist.
Ja, etwas lästig, aber es geht. Die neuen EP- Modelle sind viel angenehmer.
VauWeh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 73
지난 7일: 375
지난 30일: 1,711
전체 시간: 34,973
