주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Opening the Galaxy Watch3
필요한 것
    1. Opening the Galaxy Watch3, Unfasten the back cover screws: 1 단계, 이미지 1개 중 1개
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
      댓글 쓰기
    2. Opening the Galaxy Watch3, Wedge open the back cover: 2 단계, 이미지 2개 중 1개 Opening the Galaxy Watch3, Wedge open the back cover: 2 단계, 이미지 2개 중 2개
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
      댓글 쓰기
    3. Opening the Galaxy Watch3, Disconnect the sensor flex cable: 3 단계, 이미지 3개 중 1개 Opening the Galaxy Watch3, Disconnect the sensor flex cable: 3 단계, 이미지 3개 중 2개 Opening the Galaxy Watch3, Disconnect the sensor flex cable: 3 단계, 이미지 3개 중 3개
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      댓글 쓰기
    4. Opening the Galaxy Watch3, Remove the back cover: 4 단계, 이미지 2개 중 1개 Opening the Galaxy Watch3, Remove the back cover: 4 단계, 이미지 2개 중 2개
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
134,897 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,589개를 작성함
6가이드 댓글
where can I get the galaxy watch3 rubber gasket?
regards
Miguel Vera - 답글 공유
That’s a good question. As for the previous models it is very hard to find those rubber gaskets. Using a “liquid rubber gasket” might be one solution to that. (Use carefully to not spill too much on and into the watch)
Tobias Isakeit - 답글 공유
I tried to remove all of the screws from the back cover, but 3 of the 4 screws remained and seemed to be fused to the main base of the watch. One of the screws was stripped. Now only 1 screw is engaged with the back cover. (I might need to replace the back cover. My watch is glitching which is draining the battery. I would like to fix the problems myself. Where can I get specific advice?
Antoinette - 답글 공유
Hallo Hallo..Ich kann gar nicht offnen galaxy watch 4 classic.Fast alle schraube dreher gekauft aber für nichts einfach geht nicht raus schraube.wollte ich akku wechseln..kann mir jemand helfen?
Danke
maia margishvili - 답글 공유
@isakrittl Du schreibst: "Achte darauf, dass die Gummidichtung (rot markiert) in Ordnung ist. Falls sie beschädigt ist, ersetze sie beim Zusammenbau durch eine neue, damit die Uhr wasserdicht bleibt."
Wo bekomme ich denn eine neue her? Hab nirgends eine gefunden... Danke!
Steffen Politzky - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 33
지난 30일: 114
전체 시간: 4,996
