주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Optoma HD20 Color Wheel Replacement
필요한 것
    1. Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: 1 단계, 이미지 2개 중 1개 Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: 1 단계, 이미지 2개 중 2개
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      댓글 쓰기
    2. Optoma HD20 Color Wheel Replacement: 2 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      댓글 쓰기
    3. Optoma HD20 Color Wheel Replacement: 3 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      댓글 쓰기
    4. Optoma HD20 Color Wheel Replacement: 4 단계, 이미지 1개 중 1개
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      댓글 쓰기
    1. Optoma HD20 Color Wheel Replacement, Color Wheel: 5 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to remove the wiring.
      댓글 쓰기
    2. Optoma HD20 Color Wheel Replacement: 6 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
      댓글 쓰기
    3. Optoma HD20 Color Wheel Replacement: 7 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
      댓글 쓰기
    4. Optoma HD20 Color Wheel Replacement: 8 단계, 이미지 1개 중 1개
      • Using a flat head screw driver unscrew the back part to release the color wheel.
      • Do this carefully because these screws do not pull out.
      댓글 쓰기
    5. Optoma HD20 Color Wheel Replacement: 9 단계, 이미지 1개 중 1개
      • Once unscrewed, remove the color wheel, and replace the part.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Trever
회원 가입일: 01/22/15
1,282 평판
안내서 6개를 작성함
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 회원
CPSU-MANESS-W15S21G23
4 회원들
안내서 13개를 작성함
3가이드 댓글
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
srbaucom - 답글 공유
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter - 답글 공유
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
dlwalter - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 44
전체 시간: 9,901
