주요 콘텐츠로 건너뛰기
Oral-B Black 7000 Motor Replacement
필요한 것
  1. Oral-B Black 7000 Motor Replacement, Induction Charging Coil: 1 단계, 이미지 3개 중 1개 Oral-B Black 7000 Motor Replacement, Induction Charging Coil: 1 단계, 이미지 3개 중 2개 Oral-B Black 7000 Motor Replacement, Induction Charging Coil: 1 단계, 이미지 3개 중 3개
    • Use the charging station to remove the a small plastic plug from the end of the toothbrush by inserting the charging station into the end insert and twisting counter-clockwise by 90 degrees.
  2. Oral-B Black 7000 Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the end cap from the bottom of the toothbrush by prying it off with a spudger.
  3. Oral-B Black 7000 Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top cap by using a spudger to pry the plastic ring off of the toothbrush frame.
  4. Oral-B Black 7000 Motor Replacement: 4 단계, 이미지 2개 중 1개 Oral-B Black 7000 Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger to loosen the two plastic tabs next to the induction coil that secure the internal assembly to the frame.
    • Push on the rotating head in order to pop the assembly out of the black plastic casing.
    • You can also use a spudger to leverage the assembly out, but this may break the copper wire connected to the induction coil, so be careful.
    You need to release the induction coil’s plastic clips before you try to slide it out! This is a key missing step.
    Matthew Dowdeswell - 답글
    I agree with Matthew. You must insert a spudger and release the plastic clips while pressing down on the rotating head. I held the rotating head with a pair of pliars and then released the plastic clips and it popped right out.
    Brian Davis -
    i third that, this needs to be added ASAP, you have no chance of getting it out without unclicking those two latches that lock the inner assembly to the outer casing.
    Rainer Joos - 답글
    I'd recommend changing this to say where these tabs are. Basically, you insert the spudger between the left and right side plastic arms/tabs going to the coil assembly and the body. If you have light pressure applied to the head at the right time, you'll feel them move when you insert a spudger and put a tiny bit of leverage.
    Ryan Novosielski - 답글
    You can see these tabs most easily in step 7. The tab shown in the second photo doesn't really have anything to do with anything (maybe that's the ill-advised leverage method).
  5. Oral-B Black 7000 Motor Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Unwrap the ends of the wires from the white plastic pegs using a pair of tweezers.
    • Each wire end is wrapped around the peg 3-4 times.
    Unnecessary step for battery replacement! The electrode of the battery is solely the single solder point in the middle and the battery comes out just as well if you just leave the coil. If all you want is to replace the battery. just leave the coil, It’s fiddly and risky to break the wire and more work, only disadvantages. Good efforts!
    Rainer Joos - 답글
    I'm not doing this right now, but thank you!
    Ryan Novosielski -
    Achtung dieser Schritt ist für den reinen Akkutausch unnötig und quasi falsch! Die Spule kann verbleiben, der Akku ist einzig die einzelne mittige Lötstelle!
    Rainer Joos - 답글
  6. Oral-B Black 7000 Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Melt the solder at the two pads on either side of the top of the motherboard. This will require a high heat soldering iron. Remove the wire from the solder pads using tweezers once the solder melts.
  7. Oral-B Black 7000 Motor Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the induction coil by pulling the plastic tabs out of their keepers.
    • A spudger can be used to remove the plastic tabs from their keepers if neccessary.
  8. Oral-B Black 7000 Motor Replacement, Motor: 8 단계, 이미지 1개 중 1개
    • Desolder the red LED wires from the solder pads near the rotating head of the device.
    • These wires are quite delicate, so be sure the solder is fully melted before attempting to pull the wire out.
  9. Oral-B Black 7000 Motor Replacement: 9 단계, 이미지 2개 중 1개 Oral-B Black 7000 Motor Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the plastic housing and the LED from the device.
    Hello, where did you found the motherboard ?
    Valentin COMBEL - 답글
  10. Oral-B Black 7000 Motor Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the spring from the housing using a nylon spudger.
    • Use a nylon spudger rather than a metal one in order to minimize the risk of puncturing the battery.
  11. Oral-B Black 7000 Motor Replacement: 11 단계, 이미지 3개 중 1개 Oral-B Black 7000 Motor Replacement: 11 단계, 이미지 3개 중 2개 Oral-B Black 7000 Motor Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the motor housing from the plastic casing. This can be accomplished by using the nylon spudger to pry the motor housing out of the supporting structures.
    • The physical parts holding onto the motor are plastic knobs built into the plastic casing. Any manipulation done to the casing to remove the motor should be done within reason so that the casing is able to be reused.
    Where do I get a replacement motor?
    David Register - 답글
  12. Oral-B Black 7000 Motor Replacement: 12 단계, 이미지 2개 중 1개 Oral-B Black 7000 Motor Replacement: 12 단계, 이미지 2개 중 2개
    • Desolder the motor terminals from the motherboard and remove the motor assembly.
    How do I know if I need a new motor? My battery seems fine. My toothbrush buzzes when I turn it on, and I can hear it cycle the different modes when I push the mode button, but the head won’t swivel
    Laura - 답글
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jonathan Bowyer
회원 가입일: 11/06/17
393 평판
안내서 3개를 작성함
IUPUI, Team S1-G1, Harley Fall 2017 IUPUI, Team S1-G1, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G1
3 회원들
안내서 16개를 작성함
댓글 4개
Hallo,
Super-Anleitung. Kannst Du verraten, was für einen Motor man zur Austausch benötigt?
Spannung, Leistung, Umdrehungen, Maße, etc.?
Und vielleicht eine Bezugsquelle.
Danke Dir,
Kai
Kai Richter - 답글
How do I know if the motor needs replacing? My battery seems fine. The toothbrush buzzes and I can hear it change modes when I push the mode button, but the head doesn’t swivel. Thanks
Laura - 답글
Die Spule unten muss nicht ab! Woher bekommst du eine Ersatz motor? Im Internet findet man Nichts?!
Hans Wurst - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 20
지난 30일: 78
전체 시간: 4,783
