주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Orbic Wonder Battery Replacement
필요한 것
  1. Orbic Wonder Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Orbic Wonder Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Orbic Wonder Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
    댓글 쓰기
  2. Orbic Wonder Battery Replacement: 2 단계, 이미지 3개 중 1개 Orbic Wonder Battery Replacement: 2 단계, 이미지 3개 중 2개 Orbic Wonder Battery Replacement: 2 단계, 이미지 3개 중 3개
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
    댓글 쓰기
  3. Orbic Wonder Battery Replacement: 3 단계, 이미지 3개 중 1개 Orbic Wonder Battery Replacement: 3 단계, 이미지 3개 중 2개 Orbic Wonder Battery Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
    댓글 쓰기
  4. Orbic Wonder Battery Replacement: 4 단계, 이미지 3개 중 1개 Orbic Wonder Battery Replacement: 4 단계, 이미지 3개 중 2개 Orbic Wonder Battery Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
    댓글 쓰기
  5. Orbic Wonder Battery Replacement: 5 단계, 이미지 3개 중 1개 Orbic Wonder Battery Replacement: 5 단계, 이미지 3개 중 2개 Orbic Wonder Battery Replacement: 5 단계, 이미지 3개 중 3개
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Grant Adler
회원 가입일: 09/17/19
859 평판
안내서 5개를 작성함
3가이드 댓글
where do you buy the replacement battery at ?
ricotoomo - 답글 공유
Where can I buy a replacement battery
Robert Smith - 답글 공유
Thank you big help your smart
gansterms123 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 48
전체 시간: 8,218
