주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Orbic Wonder Screen Replacement
필요한 것
  1. Orbic Wonder Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
    댓글 쓰기
  2. Orbic Wonder Screen Replacement: 2 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 2 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 2 단계, 이미지 3개 중 3개
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
    댓글 쓰기
  3. Orbic Wonder Screen Replacement: 3 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 3 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
    댓글 쓰기
  4. Orbic Wonder Screen Replacement: 4 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 4 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
    댓글 쓰기
  5. Orbic Wonder Screen Replacement: 5 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 5 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 5 단계, 이미지 3개 중 3개
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
    댓글 쓰기
  6. Orbic Wonder Screen Replacement, Speaker: 6 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement, Speaker: 6 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement, Speaker: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $7.95
    • Remove the anti-static wrist strap.
    • Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
    • Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
    댓글 쓰기
  7. Orbic Wonder Screen Replacement: 7 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $3.99
    댓글 쓰기
  8. Orbic Wonder Screen Replacement, Charging Port Circuit Board: 8 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement, Charging Port Circuit Board: 8 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement, Charging Port Circuit Board: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Detach the metal casing at the bottom of the phone.
    • Unplug the cable connector.
    • Use a pair of angled tweezers to unplug the black wire.
    댓글 쓰기
  9. Orbic Wonder Screen Replacement: 9 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 9 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Using a pair of angled tweezers, disconnect the connector chip.
    • With the angled tweezers, gently lift (but do not remove) the green circuit board from the phone.
    댓글 쓰기
  10. Orbic Wonder Screen Replacement: 10 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Using a pair of angled tweezers, disconnect the attachment to the microphone labeled "JD," and completely remove the circuit board.
    댓글 쓰기
  11. Orbic Wonder Screen Replacement, Screen: 11 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement, Screen: 11 단계, 이미지 2개 중 2개
    • Remove the six 2mm Phillips #000 screws from the motherboard.
    댓글 쓰기
  12. Orbic Wonder Screen Replacement: 12 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the leftmost metal protector.
    • Repeat this process for the other metal protector directly above the battery.
    댓글 쓰기
  13. Orbic Wonder Screen Replacement: 13 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 13 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Disconnect the "L" shaped plug connecting the battery to the circuit board.
    • Carefully disconnect the small gold connecting wire.
    • Disconnect the rectangular piece.
    • Each of these steps are very delicate. Use a pair of tweezers to avoid causing damage.
    댓글 쓰기
  14. Orbic Wonder Screen Replacement: 14 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Unplug the power button connector.
    • Unplug the circuit connector above the battery.
    • These are very delicate and important connections. Be sure to use a pair of tweezers to avoid causing damage.
    댓글 쓰기
  15. Orbic Wonder Screen Replacement: 15 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Carefully remove the protective sticker. This will expose the camera and its connector.
    댓글 쓰기
  16. Orbic Wonder Screen Replacement: 16 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Disconnect the camera connector.
    댓글 쓰기
  17. Orbic Wonder Screen Replacement: 17 단계, 이미지 1개 중 1개
    • The circuit board should now be loose. Disconnect it, and remove it from the phone housing.
    댓글 쓰기
  18. Orbic Wonder Screen Replacement: 18 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 18 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 18 단계, 이미지 3개 중 3개
    • Using the iOpener, heat the screen's edges to loosen the adhesive holding the screen in place.
    • This will make the phone very warm. Gloves may be necessary depending on the level of heat required.
    • Using the Jimmy and opening picks, gently pry the screen from the phone housing.
    댓글 쓰기
  19. Orbic Wonder Screen Replacement: 19 단계, 이미지 2개 중 1개 Orbic Wonder Screen Replacement: 19 단계, 이미지 2개 중 2개
    • Push the gold lower screen connector wire through the hole.
    • Do the same to the gold upper screen connector wire.
    댓글 쓰기
  20. Orbic Wonder Screen Replacement: 20 단계, 이미지 3개 중 1개 Orbic Wonder Screen Replacement: 20 단계, 이미지 3개 중 2개 Orbic Wonder Screen Replacement: 20 단계, 이미지 3개 중 3개
    • Using your hands, separate the screen from the rest of the phone, ensuring that the connector wires go through the openings without ripping.
    • The screen is completely detached from the rest of the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Grant Adler
회원 가입일: 09/17/19
859 평판
안내서 5개를 작성함
3가이드 댓글
how can and or can I swap media files from orbic wonder “with damaged screen “ to a gaxalxy a01
Ron Harrell - 답글 공유
My orbic was over amped.7 volts burned something out.it turns on but nothing works.and the screen is light grey.how do i repair this plz thank you. 209crazo
209 Crazo - 답글 공유
I need orbic lcd
Gzn Khan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 53
전체 시간: 4,119
