주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oregon Scientific Meep! X2 Battery Replacement
필요한 것
    1. Oregon Scientific Meep! X2 Battery Replacement, Rear Casing: 1 단계, 이미지 1개 중 1개
      • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
      댓글 쓰기
    2. Oregon Scientific Meep! X2 Battery Replacement: 2 단계, 이미지 3개 중 1개 Oregon Scientific Meep! X2 Battery Replacement: 2 단계, 이미지 3개 중 2개 Oregon Scientific Meep! X2 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
      댓글 쓰기
    3. Oregon Scientific Meep! X2 Battery Replacement: 3 단계, 이미지 3개 중 1개 Oregon Scientific Meep! X2 Battery Replacement: 3 단계, 이미지 3개 중 2개 Oregon Scientific Meep! X2 Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Use the plastic opening tools to undo the clips around the edges of the device.
      댓글 쓰기
    1. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: 4 단계, 이미지 3개 중 1개 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: 4 단계, 이미지 3개 중 2개 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: 4 단계, 이미지 3개 중 3개
      • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
      • Pull lightly on the ribbon cable to remove it.
      댓글 쓰기
    2. Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: 5 단계, 이미지 2개 중 1개 Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: 5 단계, 이미지 2개 중 2개
      • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
      댓글 쓰기
    3. Oregon Scientific Meep! X2 Battery Replacement: 6 단계, 이미지 2개 중 1개 Oregon Scientific Meep! X2 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Use a soldering station to unsolder the battery wires from the motherboard.
      • In the case of screen or screen sensor replacement, disregard desoldering steps.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
J'mel Henneman
회원 가입일: 01/20/15
864 평판
안내서 8개를 작성함
USF Tampa, Team 9-1, Blackwell Winter 2015 USF Tampa, Team 9-1, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G1
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 1,859
