주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oregon Scientific RM318PA Lens Replacement
필요한 것
    1. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 1 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 1 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 1 단계, 이미지 3개 중 3개
      • Hold clock so the screen is facing away from you.
      • Using your thumbs, push up on battery cover to remove.
      • With your other hand, pull down on the A/C Adapter jack to remove.
      댓글 쓰기
    2. Oregon Scientific RM318PA Lens Replacement, Batteries: 2 단계, 이미지 1개 중 1개
      • Remove batteries by pushing a battery toward the spring.
      • Lift battery out at an angle. Repeat with second battery.
      댓글 쓰기
    3. Oregon Scientific RM318PA Lens Replacement, Projection Arm: 3 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Projection Arm: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
      • Once screws are removed, lift the back up and off of the projection arm.
      댓글 쓰기
    4. Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: 4 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
      댓글 쓰기
    5. Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: 5 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: 5 단계, 이미지 2개 중 2개
      • Use a Plastic Opening Tool to pry open the front of the projection arm casing. Start at the top of the projection arm.
      • Once top is partially open, use a Spudger to pry at the side of the projection arm.
      댓글 쓰기
    6. Oregon Scientific RM318PA Lens Replacement, Projection Beam: 6 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Lens Replacement, Projection Beam: 6 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Lens Replacement, Projection Beam: 6 단계, 이미지 3개 중 3개
      • Turn the clock on its side. Slide the focus wheel forward with your thumb.
      • The Projection Beam and Focus Wheel Component should now be free of Projection Arm.
      • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
      댓글 쓰기
    7. Oregon Scientific RM318PA Lens Replacement, The Lens: 7 단계, 이미지 1개 중 1개
      • The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
      댓글 쓰기
    8. Oregon Scientific RM318PA Lens Replacement, Tape: 8 단계, 이미지 1개 중 1개
      • Apply tape to the lens for safe removal and prevention of injury.
      댓글 쓰기
    9. Oregon Scientific RM318PA Lens Replacement, Focus Knob: 9 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Focus Knob: 9 단계, 이미지 2개 중 2개
      • Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip.
      • Pry apart the pieces of casing holding the focus knob in place and remove the knob.
      댓글 쓰기
    10. Oregon Scientific RM318PA Lens Replacement, Internal Casing: 10 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Lens Replacement, Internal Casing: 10 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Lens Replacement, Internal Casing: 10 단계, 이미지 3개 중 3개
      • Insert the spudger into the opening above the hinge on the side of the casing.
      • Press down firmly until the case opens.
      댓글 쓰기
    11. Oregon Scientific RM318PA Lens Replacement, Lens Removal: 11 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Lens Removal: 11 단계, 이미지 2개 중 2개
      • Pull apart the casing and gently slide lens from pocket.
      • Be sure to replace with a concave lens.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Maxine Holden
회원 가입일: 10/27/14
500 평판
안내서 4개를 작성함
1가이드 댓글
Hi, I’ve this alarm clock with missing piezo/speaker, can anyone take a picture of the main board showing the pads for it?
Mastto geppetto - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 3,166
