주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Osmo Mobile Bluetooth Module Replacement
필요한 것
    1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: 1 단계, 이미지 2개 중 1개 Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: 1 단계, 이미지 2개 중 2개
      • Remove gimbal from base handle by loosening round plate found at the top of the handle.
      댓글 쓰기
    2. Osmo Mobile Bluetooth Module Replacement: 2 단계, 이미지 2개 중 1개 Osmo Mobile Bluetooth Module Replacement: 2 단계, 이미지 2개 중 2개
      • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
      • Carefully detach handle from gimbal and disconnect the cable that connects the two.
      댓글 쓰기
    3. Osmo Mobile Bluetooth Module Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
      댓글 쓰기
    4. Osmo Mobile Bluetooth Module Replacement: 4 단계, 이미지 2개 중 1개 Osmo Mobile Bluetooth Module Replacement: 4 단계, 이미지 2개 중 2개
      • Remove joystick by gently pulling away from handle
      댓글 쓰기
    5. Osmo Mobile Bluetooth Module Replacement: 5 단계, 이미지 3개 중 1개 Osmo Mobile Bluetooth Module Replacement: 5 단계, 이미지 3개 중 2개 Osmo Mobile Bluetooth Module Replacement: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
      • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
      댓글 쓰기
    6. Osmo Mobile Bluetooth Module Replacement: 6 단계, 이미지 3개 중 1개 Osmo Mobile Bluetooth Module Replacement: 6 단계, 이미지 3개 중 2개 Osmo Mobile Bluetooth Module Replacement: 6 단계, 이미지 3개 중 3개
      • Locate four screws directly on top of handle.
      • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
      • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
      • Remove the remaining two screws found on the front of the faceplate.
      • Remove the rest of the face plate shell.
      댓글 쓰기
    1. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 7 단계, 이미지 3개 중 1개 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 7 단계, 이미지 3개 중 2개 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 7 단계, 이미지 3개 중 3개
      • Locate and remove the black screw found at the base of the grey mounting plate.
      • Remove the grey face plate.
      댓글 쓰기
    2. Osmo Mobile Bluetooth Module Replacement: 8 단계, 이미지 2개 중 1개 Osmo Mobile Bluetooth Module Replacement: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Open the battery hatch and remove it by using the tweezers to press the hinge into the device.
      • Remove the black screw located underneath where the battery hatch was.
      댓글 쓰기
    3. Osmo Mobile Bluetooth Module Replacement: 9 단계, 이미지 2개 중 1개 Osmo Mobile Bluetooth Module Replacement: 9 단계, 이미지 2개 중 2개
      • Use the spudger to remove the front handle casing by sliding the spudger into the area between the handle grooves.
      • Slide the spudger around the groove to find the 6 clasps that hold the front part of the handle, and unclasp them.
      • Take off the front handle section to reveal the whole interior of the device.
      댓글 쓰기
    4. Osmo Mobile Bluetooth Module Replacement: 10 단계, 이미지 3개 중 1개 Osmo Mobile Bluetooth Module Replacement: 10 단계, 이미지 3개 중 2개 Osmo Mobile Bluetooth Module Replacement: 10 단계, 이미지 3개 중 3개
      • Locate and remove the black screw in the center of the motherboard chip.
      • Remove motherboard and replace.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
William Tyler Wills
회원 가입일: 09/28/17
432 평판
안내서 4개를 작성함
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017 회원
USFT-NANCE-F17S2G1
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 31
전체 시간: 2,299
