주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oster 6329 Lever Catch Spring Replacement
필요한 것
    1. Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: 1 단계, 이미지 2개 중 1개 Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: 1 단계, 이미지 2개 중 2개
      • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
      댓글 쓰기
    2. Oster 6329 Lever Catch Spring Replacement: 2 단계, 이미지 1개 중 1개
      • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
      댓글 쓰기
    3. Oster 6329 Lever Catch Spring Replacement: 3 단계, 이미지 1개 중 1개
      • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
      • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
      댓글 쓰기
    4. Oster 6329 Lever Catch Spring Replacement: 4 단계, 이미지 2개 중 1개 Oster 6329 Lever Catch Spring Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
      댓글 쓰기
    5. Oster 6329 Lever Catch Spring Replacement: 5 단계, 이미지 2개 중 1개 Oster 6329 Lever Catch Spring Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the top outer metal shell.
      • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
      댓글 쓰기
    1. Oster 6329 Lever Catch Spring Replacement, Lever Catch Spring: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Insert the tweezers between the spring and the bottom of the lever to release the spring.
      댓글 쓰기
    2. Oster 6329 Lever Catch Spring Replacement: 7 단계, 이미지 2개 중 1개 Oster 6329 Lever Catch Spring Replacement: 7 단계, 이미지 2개 중 2개
      • Remove spring from the bottom of the lever.
      • The spring should only be connected to the top of the toaster after this is complete.
      댓글 쓰기
    3. Oster 6329 Lever Catch Spring Replacement: 8 단계, 이미지 1개 중 1개
      • Insert the tweezers between the two metal flaps located at the top of the toaster.
      • Hold the spring and turn it sideways to lay it flat along the top of the toaster.
      • Pry the spring from the top of the toaster.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Blaine Oelkers
회원 가입일: 01/24/14
131 평판
안내서 1개를 작성함
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 회원
CPSU-REGAN-W14S13G15
5 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 36
전체 시간: 1,670
