주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Overclocking your eMac
필요한 것
  1. Overclocking your eMac, Door Removal: 1 단계, 이미지 3개 중 1개 Overclocking your eMac, Door Removal: 1 단계, 이미지 3개 중 2개 Overclocking your eMac, Door Removal: 1 단계, 이미지 3개 중 3개
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
    댓글 쓰기
  2. Overclocking your eMac, Bottom Screw Removal: 2 단계, 이미지 1개 중 1개
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
    댓글 쓰기
  3. Overclocking your eMac, Top and Side Screws: 3 단계, 이미지 3개 중 1개 Overclocking your eMac, Top and Side Screws: 3 단계, 이미지 3개 중 2개 Overclocking your eMac, Top and Side Screws: 3 단계, 이미지 3개 중 3개
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
    댓글 쓰기
  4. Overclocking your eMac, Power Button Cable: 4 단계, 이미지 2개 중 1개 Overclocking your eMac, Power Button Cable: 4 단계, 이미지 2개 중 2개
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
    댓글 쓰기
  5. Overclocking your eMac, Shell Removal: 5 단계, 이미지 1개 중 1개
    • Now the entire shell can be removed from the computer.
    댓글 쓰기
  6. Overclocking your eMac, Panel Removal: 6 단계, 이미지 3개 중 1개 Overclocking your eMac, Panel Removal: 6 단계, 이미지 3개 중 2개 Overclocking your eMac, Panel Removal: 6 단계, 이미지 3개 중 3개
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
    댓글 쓰기
  7. Overclocking your eMac, Cables: 7 단계, 이미지 3개 중 1개 Overclocking your eMac, Cables: 7 단계, 이미지 3개 중 2개 Overclocking your eMac, Cables: 7 단계, 이미지 3개 중 3개
    • To remove the fan assembly, several cables must be disconnected first:
    • 3-pin fan cable
    • Ground wire, requires phillips #2 screwdriver
    • 2-pin AC cable to power supply
    댓글 쓰기
  8. Overclocking your eMac, Screws: 8 단계, 이미지 2개 중 1개 Overclocking your eMac, Screws: 8 단계, 이미지 2개 중 2개
    • Now remove the following screws securing the fan assembly:
    • 3x coarse thread phillips #2
    • 1x machine thread phillips #2
    댓글 쓰기
  9. Overclocking your eMac: 9 단계, 이미지 1개 중 1개
    • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
    댓글 쓰기
  10. Overclocking your eMac, Assembly Removal: 10 단계, 이미지 2개 중 1개 Overclocking your eMac, Assembly Removal: 10 단계, 이미지 2개 중 2개
    • You should now be able to remove the fan assembly.
    • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
    댓글 쓰기
  11. Overclocking your eMac, Bottom Connectors: 11 단계, 이미지 1개 중 1개
    • There are four connectors at the bottom of the motherboard that must be removed.
    댓글 쓰기
  12. Overclocking your eMac, Display Connector: 12 단계, 이미지 3개 중 1개 Overclocking your eMac, Display Connector: 12 단계, 이미지 3개 중 2개 Overclocking your eMac, Display Connector: 12 단계, 이미지 3개 중 3개
    • There is a large display connector that must be removed. This can be done by squeezing the tabs and pulling.
    댓글 쓰기
  13. Overclocking your eMac, Power Button Cable: 13 단계, 이미지 1개 중 1개
    • The power button cable may be tucked in the casing, you will need to un-tuck it.
    댓글 쓰기
  14. Overclocking your eMac, Screws: 14 단계, 이미지 3개 중 1개 Overclocking your eMac, Screws: 14 단계, 이미지 3개 중 2개 Overclocking your eMac, Screws: 14 단계, 이미지 3개 중 3개
    • There are several phillips #2 screws that hold the eMac motherboard assembly to the rest of the computer. They will all need to be removed.
    • 2 large ones near the drive bay door.
    • 7 smaller ones scattered around
    댓글 쓰기
  15. Overclocking your eMac, Screws (Continued): 15 단계, 이미지 2개 중 1개 Overclocking your eMac, Screws (Continued): 15 단계, 이미지 2개 중 2개
    • More of the screw locations from the previous step
    댓글 쓰기
  16. Overclocking your eMac, Motherboard Assembly: 16 단계, 이미지 1개 중 1개
    • The motherboard assembly should now come free.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Emmanouil Georgopoulos
회원 가입일: 03/15/11
115 평판
안내서 1개를 작성함
2가이드 댓글
i am searching a POWER BUTTON for my old eMac(2004)
somebody can help me?
my email:cabanel.robert@orange.fr
thank you!
capitaine NEMO - 답글 공유
Where is Overclocking ?)
Pavel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 69
전체 시간: 2,795
