주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PDP Afterglow Fener Wireless Dongle USB Wire Repair
필요한 것
    1. PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 1 단계, 이미지 3개 중 1개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 1 단계, 이미지 3개 중 2개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 1 단계, 이미지 3개 중 3개
      • First, remove the heat shrink from the new USB.
      • Then remove the signal shield protection from the new USB.
      • Next, cut the 4 wire ends that are now protruding from the end of the USB.
      댓글 쓰기
    2. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 2 단계, 이미지 3개 중 1개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 2 단계, 이미지 3개 중 2개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 2 단계, 이미지 3개 중 3개
      • Then do the same process as above, for the USB wire coming out of the dongle itself.
      • Bend the wire ends so that they form hook shapes.
      • Connect the two hooks together.
      댓글 쓰기
    3. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 3 단계, 이미지 3개 중 1개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 3 단계, 이미지 3개 중 2개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 3 단계, 이미지 3개 중 3개
      • Once hooked, twist the two wires together to keep a strong connection.
      • Use a helping hand or other platform to perform the soldering.
      • Now solder the two wires together. Be careful to avoid melting the heat shrink otherwise it may get onto the copper wires.
      댓글 쓰기
    4. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 4 단계, 이미지 2개 중 1개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 4 단계, 이미지 2개 중 2개
      • Next you can use a heat gun to melt the heat shrinks together for maximum wire protection.
      댓글 쓰기
    5. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 5 단계, 이미지 2개 중 1개 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 5 단계, 이미지 2개 중 2개
      • Finally, you can cover the whole thing with either a large heat shrink, or some electrical tape.
      댓글 쓰기
결론
This guide does not require reassembly, as the guide itself is re-attaching the USB.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Thomas Williams
회원 가입일: 10/22/15
512 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G3
3 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 2,104
