주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PDP Afterglow Wired Xbox 360 Controller Button Replacement
필요한 것
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: 1 단계, 이미지 2개 중 1개 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
    댓글 쓰기
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
    댓글 쓰기
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top cover from the bottom and place next to each other.
    댓글 쓰기
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: 4 단계, 이미지 1개 중 1개
    • Remove the rubber button covers from the A, B, X, and Y buttons.
    댓글 쓰기
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 5 단계, 이미지 2개 중 1개 PDP Afterglow Wired Xbox 360 Controller Button Replacement: 5 단계, 이미지 2개 중 2개
    • Push up on the buttons from the front and pull them out from the back.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Joi Officer
회원 가입일: 09/17/15
313 평판
안내서 2개를 작성함
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G1
4 회원들
안내서 5개를 작성함
4가이드 댓글
What about removing the Dpad? i really need help.
Elijah Douglas - 답글 공유
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - 답글 공유
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson - 답글 공유
No not really I agree with homeboy cause I just took mine apart to fix drifting and the one piece clip for RB and Lb doesn’t just fit in there right
David Drinkard - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 97
전체 시간: 6,714
