주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PDP Rematch Cable Replacement
필요한 것
  1. PDP Rematch Cable Replacement, Faceplate: 1 단계, 이미지 2개 중 1개 PDP Rematch Cable Replacement, Faceplate: 1 단계, 이미지 2개 중 2개
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    댓글 쓰기
  2. PDP Rematch Cable Replacement: 2 단계, 이미지 2개 중 1개 PDP Rematch Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    댓글 쓰기
  3. PDP Rematch Cable Replacement: 3 단계, 이미지 2개 중 1개 PDP Rematch Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift off the hard cover with your hand; it should not need much force.
    댓글 쓰기
  4. PDP Rematch Cable Replacement, Cable: 4 단계, 이미지 1개 중 1개
    • Remove the two screws on the motherboard with a JIS #000 screwdriver.
    • Gently flip the motherboard up to see the other side.
    댓글 쓰기
  5. PDP Rematch Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the cable from its plug on the motherboard.
    • This should give you room to carefully detach the Male Pitch Terminal Pin Header from the Female Terminal Pin.
    댓글 쓰기
  6. PDP Rematch Cable Replacement: 6 단계, 이미지 1개 중 1개
    • Take the new cable and thread it through the slot. The terminal block should fit loosely into the slot.
    • Then, insert the Male Pitch Terminal Pin into the Female Terminal Pin.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sydney Foster
회원 가입일: 01/30/24
97 평판
안내서 1개를 작성함
1가이드 댓글
Where do I buy the replacement cord from?
Keithy Bruce - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 50
전체 시간: 676
