주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP 2000 Memory Stick Slot Replacement
필요한 것
  1. PSP 2000  Memory Stick Slot Replacement, Battery: 1 단계, 이미지 3개 중 1개 PSP 2000  Memory Stick Slot Replacement, Battery: 1 단계, 이미지 3개 중 2개 PSP 2000  Memory Stick Slot Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
    댓글 쓰기
  2. PSP 2000  Memory Stick Slot Replacement, Front Casing: 2 단계, 이미지 1개 중 1개
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
    댓글 쓰기
  3. PSP 2000  Memory Stick Slot Replacement: 3 단계, 이미지 2개 중 1개 PSP 2000  Memory Stick Slot Replacement: 3 단계, 이미지 2개 중 2개
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    댓글 쓰기
  4. PSP 2000  Memory Stick Slot Replacement: 4 단계, 이미지 2개 중 1개 PSP 2000  Memory Stick Slot Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    댓글 쓰기
  5. PSP 2000  Memory Stick Slot Replacement: 5 단계, 이미지 2개 중 1개 PSP 2000  Memory Stick Slot Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
    댓글 쓰기
  6. PSP 2000  Memory Stick Slot Replacement, Display: 6 단계, 이미지 3개 중 1개 PSP 2000  Memory Stick Slot Replacement, Display: 6 단계, 이미지 3개 중 2개 PSP 2000  Memory Stick Slot Replacement, Display: 6 단계, 이미지 3개 중 3개
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
    댓글 쓰기
  7. PSP 2000  Memory Stick Slot Replacement: 7 단계, 이미지 3개 중 1개 PSP 2000  Memory Stick Slot Replacement: 7 단계, 이미지 3개 중 2개 PSP 2000  Memory Stick Slot Replacement: 7 단계, 이미지 3개 중 3개
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    댓글 쓰기
  8. PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: 8 단계, 이미지 3개 중 1개 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: 8 단계, 이미지 3개 중 2개 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: 8 단계, 이미지 3개 중 3개
    • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
    • Slide off the left trigger along with the plastic bracket underneath.
    • Carefully pry off left trigger button using opening tools.
    • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
    댓글 쓰기
  9. PSP 2000  Memory Stick Slot Replacement: 9 단계, 이미지 2개 중 1개 PSP 2000  Memory Stick Slot Replacement: 9 단계, 이미지 2개 중 2개
    • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
    • Gently remove the memory card slot by pulling it straight out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
espinks
회원 가입일: 10/18/09
3,869 평판
안내서 5개를 작성함
Cal Poly, Team 6-3, Maness Fall 2009 Cal Poly, Team 6-3, Maness Fall 2009 회원
CPSU-MANESS-F09S6G3
5 회원들
안내서 48개를 작성함
2가이드 댓글
Thank you, i'am Zakaria Farid from Morocoo
swat4ever2015 - 답글 공유
would this work for a 2001 model?
James Ginther - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 56
지난 30일: 299
전체 시간: 32,708
