주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP 2000 Front Casing Replacement
필요한 것
  1. PSP 2000 Front Casing Replacement, Battery: 1 단계, 이미지 3개 중 1개 PSP 2000 Front Casing Replacement, Battery: 1 단계, 이미지 3개 중 2개 PSP 2000 Front Casing Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
    댓글 쓰기
  2. PSP 2000 Front Casing Replacement, Front Casing: 2 단계, 이미지 1개 중 1개
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
    댓글 쓰기
  3. PSP 2000 Front Casing Replacement: 3 단계, 이미지 2개 중 1개 PSP 2000 Front Casing Replacement: 3 단계, 이미지 2개 중 2개
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    댓글 쓰기
  4. PSP 2000 Front Casing Replacement: 4 단계, 이미지 2개 중 1개 PSP 2000 Front Casing Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    댓글 쓰기
  5. PSP 2000 Front Casing Replacement: 5 단계, 이미지 2개 중 1개 PSP 2000 Front Casing Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
pepe32290
회원 가입일: 10/19/09
1,772 평판
안내서 4개를 작성함
Cal Poly, Team 6-3, Maness Fall 2009 Cal Poly, Team 6-3, Maness Fall 2009 회원
CPSU-MANESS-F09S6G3
5 회원들
안내서 48개를 작성함
2가이드 댓글
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - 답글 공유
sorry this is a decade too late HA. i just did a swap for the plastic screen cover and yes, for anyone in the future, the plastic cover is on the front shell piece, you will need some tweezers or something narrow to get the plastic screen popped off, dont crack the front shell, the bottom gets fragile so just be slow and methodical. but its an easy swap, maybe 15 minutes. good time to clear out the lint around the joystick as well.
Scott Munier - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 61
지난 30일: 255
전체 시간: 32,425
