주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP Go Battery Replacement
필요한 것
  1. PSP Go Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 PSP Go Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
    댓글 쓰기
  2. PSP Go Battery Replacement: 2 단계, 이미지 2개 중 1개 PSP Go Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
    댓글 쓰기
  3. PSP Go Battery Replacement, Top Cover: 3 단계, 이미지 1개 중 1개
    • Pull the top cover upwards gently from its housing.
    댓글 쓰기
  4. PSP Go Battery Replacement, Left Trigger: 4 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to gently flip up the left trigger connector.
    댓글 쓰기
  5. PSP Go Battery Replacement: 5 단계, 이미지 2개 중 1개 PSP Go Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
    댓글 쓰기
  6. PSP Go Battery Replacement, Battery: 6 단계, 이미지 3개 중 1개 PSP Go Battery Replacement, Battery: 6 단계, 이미지 3개 중 2개 PSP Go Battery Replacement, Battery: 6 단계, 이미지 3개 중 3개
    • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
    • Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
    댓글 쓰기
  7. PSP Go Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
    • Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
    • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
    댓글 쓰기
  8. PSP Go Battery Replacement: 8 단계, 이미지 2개 중 1개 PSP Go Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
    • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 23명이 해당 안내서를 완성하였습니다.
12가이드 댓글
this was so quick . I have been trying to get this repaired for years, only to hear throw it away there is no fix . sharing love
mainemade4u - 답글 공유
a couple of notes my cover came completely off in the beginning step without a problem or broken screws. next i didnt und the wired cabled beside the clicker and it wasnt in the way.
mainemade4u - 답글 공유
After replace a new battery my psp go going crazy. Charge only 1 or 2 min led going to green but not fully charge. Anyone can help me to fix this
Mus Mohamed - 답글 공유
Cfw 6.61 pro update. Helppp
Mus Mohamed - 답글 공유
Thanks to this guide I was able to reseat the battery, the PSP was not turning on or charging any more, now everything is working again.
Marvin Arand - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 24
지난 7일: 156
지난 30일: 627
전체 시간: 106,515
