주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm Pre Keyboard Replacement
필요한 것
  1. Palm Pre Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
    댓글 쓰기
  2. Palm Pre Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pull up on the tab to remove the current battery.
    댓글 쓰기
  3. Palm Pre Keyboard Replacement, Antenna: 3 단계, 이미지 2개 중 1개 Palm Pre Keyboard Replacement, Antenna: 3 단계, 이미지 2개 중 2개
    • Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
    댓글 쓰기
  4. Palm Pre Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
    • Use a spudger to pry open the hinge.
    • Use tweezers to disconnect the antennas from the keypad control board.
    댓글 쓰기
  5. Palm Pre Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Palm Pre Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to pry off the (black and yellow) back frame.
    • Disregard the main part of the phone at this point and look only at the inside of the removed back frame. (You will need the main part of the phone for access to the keyboard and motherboard)
    댓글 쓰기
  6. Palm Pre Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Find the small circuit board at the top right and desolder the wires that are connected to it.
    • This step is only necessary for antenna removal.
    댓글 쓰기
  7. Palm Pre Keyboard Replacement, Keypad Control Board: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the two ribbon cable connectors using tweezers.
    댓글 쓰기
  8. Palm Pre Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Palm Pre Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to remove the keypad control board.
    • There is heavy adhesive connecting this part to the keypad sensors.
    댓글 쓰기
  9. Palm Pre Keyboard Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Slide the keyboard away from the phone.
    • Use tweezers to separate the keyboard from the phone if adhesive is inhibiting removal.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
noha
회원 가입일: 04/12/12
139 평판
안내서 6개를 작성함
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 회원
CPSU-MANESS-S12S7G31
3 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 29
전체 시간: 1,561
