주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm Treo Pro Motherboard Replacement
필요한 것
  1. Palm Treo Pro Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Palm Treo Pro Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Palm Treo Pro Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Press down on the back of the case and slide forward to remove it.
    댓글 쓰기
  2. Palm Treo Pro Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by pulling up on the tab near the camera lens.
    • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
    댓글 쓰기
  3. Palm Treo Pro Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 1개 Palm Treo Pro Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 2개 Palm Treo Pro Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 3개
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
    댓글 쓰기
  4. Palm Treo Pro Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Palm Treo Pro Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Palm Treo Pro Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
    댓글 쓰기
  5. Palm Treo Pro Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Palm Treo Pro Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Palm Treo Pro Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
    댓글 쓰기
  6. Palm Treo Pro Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Palm Treo Pro Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Palm Treo Pro Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
    댓글 쓰기
  7. Palm Treo Pro Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Palm Treo Pro Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
    댓글 쓰기
  8. Palm Treo Pro Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Palm Treo Pro Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Palm Treo Pro Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
    댓글 쓰기
  9. Palm Treo Pro Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Palm Treo Pro Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Palm Treo Pro Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nadia Carroll
회원 가입일: 04/11/13
11 평판
안내서 1개를 작성함
Cal Poly, Team 8-59, Johann Spring 2013 Cal Poly, Team 8-59, Johann Spring 2013 회원
CPSU-JOHANN-S13S8G59
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 35
전체 시간: 667
