주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm Zire 31 Battery Replacement
필요한 것
    1. Palm Zire 31 Battery Replacement, Case: 1 단계, 이미지 1개 중 1개
      • Unscrew the two 7.35mm Torx T6 screws.
      댓글 쓰기
    2. Palm Zire 31 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
      댓글 쓰기
    3. Palm Zire 31 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
      댓글 쓰기
    4. Palm Zire 31 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
      댓글 쓰기
    1. Palm Zire 31 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • Using the spudger, pry the battery from where it is glued from the motherboard and observe that the leads are soldered on.
      댓글 쓰기
    2. Palm Zire 31 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Heating up the soldering iron properly, place the wick against the solder bulbs and heat the solder until the solder wick sucks up the solder.
      • Be careful to not leave the soldering iron on the board too long as you may remove the copper leads or damage the motherboard.
      • Solder the new battery's leads to the motherboard by taking the heated iron and heating the exposed wires of the leads and placing the solder in contact with the leads so the solder heats up and flows onto the leads.
      • Pull away the heat immediately once the solder has flowed and let the board cool to avoid damage to the board (or burns on your hand).
      댓글 쓰기
    3. Palm Zire 31 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Place the battery back on the board gently.
      • The glue on the board should still stick, and you will want to be sure its exactly where it was or else the device will not reassemble properly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Gabe
회원 가입일: 01/23/11
501 평판
안내서 5개를 작성함
Cal Poly, Team 5-21, Amido Winter 2011 Cal Poly, Team 5-21, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G21
4 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 42
전체 시간: 5,081
