주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm Zire m150 Control Button Replacement
필요한 것
    1. Palm Zire m150 Control Button Replacement, Control Button: 1 단계, 이미지 2개 중 1개 Palm Zire m150 Control Button Replacement, Control Button: 1 단계, 이미지 2개 중 2개
      • Lift up the flap on the Palm Zire M150.
      • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
      • If you wish to remove it, gently lift up on the flap and pull horizontally. It should come off without an issue.
      댓글 쓰기
    2. Palm Zire m150 Control Button Replacement: 2 단계, 이미지 1개 중 1개
      • Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
      댓글 쓰기
    3. Palm Zire m150 Control Button Replacement: 3 단계, 이미지 2개 중 1개 Palm Zire m150 Control Button Replacement: 3 단계, 이미지 2개 중 2개
      • Gently pull the top half and bottom half off the device apart using both hands so that it looks like the second photo.
      • You can use your finger nails to pry apart the top half and the bottom half of the device. If that doesn't work, use the opening picks from the toolkit.
      댓글 쓰기
    4. Palm Zire m150 Control Button Replacement: 4 단계, 이미지 1개 중 1개
      • This is the button that you are going to be replacing. Grab the grey button and pull it apart from the device.
      • If you are not replacing the button and you are just cleaning it, make sure you are gentle when you pull it from the device so that you don't break the button.
      • You can use compressed air to clean them or an alcohol wipe.
      댓글 쓰기
    5. Palm Zire m150 Control Button Replacement: 5 단계, 이미지 1개 중 1개
      • The button is now off of the device. If you are cleaning it, use the compressed air or the alcohol wipe.
      • If installing a new button, throw away the one you just took off and snap the new one back on the white piece.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kate
회원 가입일: 01/26/16
528 평판
안내서 5개를 작성함
USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 회원
USFSM-STEWART-S16S1G3
5 회원들
안내서 18개를 작성함
1가이드 댓글
Kate what hairy arms you have lol
Jimfixer - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 32
전체 시간: 862
