주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm m105 Batteries Replacement
    1. Palm m105 Batteries Replacement, Batteries: 1 단계, 이미지 1개 중 1개
      • Press the latch on the battery door on the back of the device and pull outwards.
      • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
      댓글 쓰기
    2. Palm m105 Batteries Replacement: 2 단계, 이미지 1개 중 1개
      • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
      • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
      댓글 쓰기
    3. Palm m105 Batteries Replacement: 3 단계, 이미지 1개 중 1개
      • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Erik Thompson
회원 가입일: 10/04/11
31 평판
안내서 5개를 작성함
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G3
4 회원들
안내서 35개를 작성함
2가이드 댓글
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - 답글 공유
I have on that doesn't use batteries. It's a rechargeable one. Do you have any instructions on how to replace the internal battery?
deanplays - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 38
전체 시간: 1,720
