주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic DMC-FZ70 LCD Screen Replacement
필요한 것
  1. Panasonic DMC-FZ70 LCD Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 LCD Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
    댓글 쓰기
  2. Panasonic DMC-FZ70 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
    댓글 쓰기
  3. Panasonic DMC-FZ70 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
    댓글 쓰기
  4. Panasonic DMC-FZ70 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
    댓글 쓰기
  5. Panasonic DMC-FZ70 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
    댓글 쓰기
  6. Panasonic DMC-FZ70 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
    댓글 쓰기
  7. Panasonic DMC-FZ70 LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Panasonic DMC-FZ70 LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Panasonic DMC-FZ70 LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
    댓글 쓰기
  8. Panasonic DMC-FZ70 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 2개
    • Unscrew the five 5mm screws on the panel that you just removed.
    댓글 쓰기
  9. Panasonic DMC-FZ70 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the entire silver panel to reveal the back of the LCD screen
    댓글 쓰기
  10. Panasonic DMC-FZ70 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the LCD screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Alberto Rodriguez
회원 가입일: 01/24/17
537 평판
안내서 4개를 작성함
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017 회원
CPSU-MANESS-W17S21G3
6 회원들
안내서 12개를 작성함
5가이드 댓글
Where can I find the screen to replace the one that is cracked?
tim krikston - 답글 공유
i am not able to find the new display where-in they could ship it to INDIA
if u find any please mail me - ppavanshetty@gmail.com
Ppavan Shetty - 답글 공유
After replacement the camera won't work, turn on but it doesn't work.
Harold De La Matta - 답글 공유
After the LCD replacement my camera turn on but it doesn't work. Any ideas?
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 57
전체 시간: 3,444
