주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic DVD-RV31 Player Disk Drive Replacement
필요한 것
    1. Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Tray Cover: 1 단계, 이미지 1개 중 1개
      • Eject the disk tray from the DVD player before removing power supply.
      댓글 쓰기
    2. Panasonic DVD-RV31 Player Disk Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
      댓글 쓰기
    1. Panasonic DVD-RV31 Player Disk Drive Replacement, Outer Case: 3 단계, 이미지 2개 중 1개 Panasonic DVD-RV31 Player Disk Drive Replacement, Outer Case: 3 단계, 이미지 2개 중 2개
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      댓글 쓰기
    2. Panasonic DVD-RV31 Player Disk Drive Replacement: 4 단계, 이미지 1개 중 1개
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      댓글 쓰기
    1. Panasonic DVD-RV31 Player Disk Drive Replacement, Front Panel: 5 단계, 이미지 2개 중 1개 Panasonic DVD-RV31 Player Disk Drive Replacement, Front Panel: 5 단계, 이미지 2개 중 2개
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      댓글 쓰기
    1. Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 6 단계, 이미지 3개 중 1개 Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 6 단계, 이미지 3개 중 2개 Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 6 단계, 이미지 3개 중 3개
      • Locate the four screws securing the disk drive assembly. There are two on each side.
      • Use a narrow screwdriver to remove all four screws.
      • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
      댓글 쓰기
    2. Panasonic DVD-RV31 Player Disk Drive Replacement: 7 단계, 이미지 1개 중 1개
      • Lift assembly by the front to pull metal bracket from the power board.
      • Pull up back end and lift drive out.
      댓글 쓰기
    3. Panasonic DVD-RV31 Player Disk Drive Replacement: 8 단계, 이미지 1개 중 1개
      • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
      • Lift bracket off and reserve for re-assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
William
회원 가입일: 04/26/11
283 평판
안내서 2개를 작성함
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 회원
CPSU-GARNER-S11S18G20
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 47
전체 시간: 6,289
