주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic KX-TG6641 Base Display Screen Replacement
필요한 것
  1. Panasonic KX-TG6641 Base Display Screen Replacement, Base Display Screen: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove five screws from the back cover.
    댓글 쓰기
  2. Panasonic KX-TG6641 Base Display Screen Replacement: 2 단계, 이미지 1개 중 1개
    • To remove the back cover, use an iFixit opening tool and wedge the tool in between the loosened back charging case and the front plate.
    • Wiggle to loosen, be careful to not pry too hard as it could cause damage.
    댓글 쓰기
  3. Panasonic KX-TG6641 Base Display Screen Replacement: 3 단계, 이미지 2개 중 1개 Panasonic KX-TG6641 Base Display Screen Replacement: 3 단계, 이미지 2개 중 2개
    • To access the display screen, use a Phillips #0 screwdriver to remove the screw on the bottom right corner of the electrical panel.
    • Unclip the wires hooked into the base.
    • It's not necessary to desolder the wires.
    댓글 쓰기
  4. Panasonic KX-TG6641 Base Display Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the two phone cable connectors.
    • Use a Phillips #0 to remove the screw that is fixed in the plastic holder for the connectors.
    댓글 쓰기
  5. Panasonic KX-TG6641 Base Display Screen Replacement: 5 단계, 이미지 2개 중 1개 Panasonic KX-TG6641 Base Display Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Move the electrical panel to the side.
    • Use a Phillips #0 to remove the four screws from the brown board and lift it to access the display screen.
    • Be aware, there is a screw under the control panel, it is indicated with the central red circle.
    댓글 쓰기
  6. Panasonic KX-TG6641 Base Display Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the current display screen from the electric panel.
    • Follow this process in reverse to replace the new display screen in its place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Joseph Byrne
회원 가입일: 04/08/19
481 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 708
