소개
The TEL port is where the TEL cable plugs into on the device. If you've followed the symptoms listed in our troubleshooting guide and have determined that the TEL port is the issue, you'll need to follow this guide to reach it and replace it. Prior to beginning this guide, make sure you have access to a Philips Size #0 screwdriver and a soldering iron. Both will be needed to open the device and replace the component.
필요한 것
To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
For easier access to its wires, you can easily remove the TEL port from its resting point in the device.
