주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Lumix DMC-FX01 Front Casing Replacement
필요한 것
    1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Locate the memory card and battery card latch on the bottom of the camera.
      • Slide the latch to the open position.
      댓글 쓰기
    2. Panasonic Lumix DMC-FX01 Front Casing Replacement: 2 단계, 이미지 1개 중 1개
      • Open the battery latch, and slide the battery release lever to the right.
      댓글 쓰기
    3. Panasonic Lumix DMC-FX01 Front Casing Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the battery from the camera.
      댓글 쓰기
    1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Rear Casing: 4 단계, 이미지 1개 중 1개
      • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Panasonic Lumix DMC-FX01 Front Casing Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
      댓글 쓰기
    3. Panasonic Lumix DMC-FX01 Front Casing Replacement: 6 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-FX01 Front Casing Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the left side casing.
      댓글 쓰기
    4. Panasonic Lumix DMC-FX01 Front Casing Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
      댓글 쓰기
    5. Panasonic Lumix DMC-FX01 Front Casing Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the bottom right panel.
      댓글 쓰기
    6. Panasonic Lumix DMC-FX01 Front Casing Replacement: 9 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-FX01 Front Casing Replacement: 9 단계, 이미지 2개 중 2개
      • Gently remove the back casing.
      • Start at the bottom and carefully pry towards the top to get this piece free.
      댓글 쓰기
    1. Panasonic Lumix DMC-FX01 Front Casing Replacement, LCD Screen: 10 단계, 이미지 1개 중 1개
      • Gently lift up the LCD screen.
      • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
      • It should fall out on its own or with a gentle tug.
      댓글 쓰기
    2. Panasonic Lumix DMC-FX01 Front Casing Replacement: 11 단계, 이미지 1개 중 1개
      • Gently tug the thicker ribbon to remove it from its housing.
      댓글 쓰기
    1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: 12 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: 12 단계, 이미지 2개 중 2개
      • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
      • There may be a third screw the the right of the lens assembly.
      댓글 쓰기
    2. Panasonic Lumix DMC-FX01 Front Casing Replacement: 13 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-FX01 Front Casing Replacement: 13 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-FX01 Front Casing Replacement: 13 단계, 이미지 3개 중 3개
      • Carefully remove the upper assembly, which houses the buttons and the flash battery.
      댓글 쓰기
    3. Panasonic Lumix DMC-FX01 Front Casing Replacement: 14 단계, 이미지 1개 중 1개
      • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Andrew
회원 가입일: 10/11/10
396 평판
안내서 4개를 작성함
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 회원
CPSU-REGAN-F10S9G22
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 27
전체 시간: 4,724
