주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement
필요한 것
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Move the switch on the battery door to the Open position.
      • The door will automatically swing open after you let it go.
      댓글 쓰기
    2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 2 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 2 단계, 이미지 2개 중 2개
      • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
      • Keep your finger clear of the battery when it pops out.
      댓글 쓰기
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Memory Card: 3 단계, 이미지 1개 중 1개
      • Push the memory card in and let go.
      • The memory card will pop out slightly.
      • Pull out the memory card.
      댓글 쓰기
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: 4 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: 4 단계, 이미지 2개 중 2개
      • Unscrew the small screws on the sides of the camera.
      • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
      댓글 쓰기
    2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 5 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 5 단계, 이미지 2개 중 2개
      • Unscrew the three small screws on the bottom(#00P, 3.3mm).
      • The bottom will fall off.
      댓글 쓰기
    3. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 6 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 6 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 6 단계, 이미지 3개 중 3개
      • Lift up the bottom back cover by prying the bottom edge with the spudger.
      • Gently lift up the back cover with your hand from the bottom to the top.
      댓글 쓰기
    4. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 7 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 7 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: 7 단계, 이미지 3개 중 3개
      • Lift the tabs on the ZIF connectors.
      • The ribbon cables should easily come out of the ZIF connectors.
      댓글 쓰기
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: 8 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: 8 단계, 이미지 2개 중 2개
      • Gently wiggle out the top motherboard.
      • The buttons are hardwired into this logic board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Karissa
회원 가입일: 04/13/12
71 평판
안내서 8개를 작성함
Cal Poly, Team 6-23, Amido Spring 2012 Cal Poly, Team 6-23, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G23
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 34
전체 시간: 1,292
