주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement
필요한 것
  1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
    댓글 쓰기
  2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 2 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
    댓글 쓰기
  3. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 3 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 3 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 3 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
    댓글 쓰기
  4. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 4 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 4 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
    댓글 쓰기
  5. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
    댓글 쓰기
  6. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
    댓글 쓰기
  7. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
    댓글 쓰기
  8. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
    댓글 쓰기
  9. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 9 단계, 이미지 1개 중 1개
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
    댓글 쓰기
  10. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 10 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 10 단계, 이미지 2개 중 2개
    • Push on the back panel buttons from the frontside of the back cover.
    • There might be some adhesives holding the back panel buttons to the cover. Extra force may be necessary.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Kingsley East
회원 가입일: 10/30/16
474 평판
안내서 4개를 작성함
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G9
3 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 23
전체 시간: 1,194
