주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Lumix ZS50 Flash Assembly Replacement
필요한 것
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Turn the camera off and identify the battery door located on the bottom of the camera.
      댓글 쓰기
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 2 단계, 이미지 2개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 2 단계, 이미지 2개 중 2개
      • Slide the "open" latch to the left: the battery door should spring open.
      • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
      댓글 쓰기
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • To release the battery, slide the white release lever next to the SD card slot.
      • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
      댓글 쓰기
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • The battery should now be released; you may now remove the battery from the camera body.
      댓글 쓰기
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: 5 단계, 이미지 3개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: 5 단계, 이미지 3개 중 2개 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: 5 단계, 이미지 3개 중 3개
      • Orient the camera so the bottom is facing up and the battery door is on the right side.
      • Remove four black screws from the bottom of the camera.
      • Remove two black screws from the right side of the camera.
      • Remove one black screw from the left side of the camera.
      댓글 쓰기
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 6 단계, 이미지 2개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the casing from the camera by hand or using a plastic opening tool.
      댓글 쓰기
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: 7 단계, 이미지 2개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 7 단계, 이미지 2개 중 2개
      • Use a spudger to lift up and tug off the green button board.
      • Be careful to not damage the attached ribbon cable.
      댓글 쓰기
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: 8 단계, 이미지 3개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 8 단계, 이미지 3개 중 2개 Panasonic Lumix ZS50 Flash Assembly Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the screen using the plastic opening tool, prying from the top.
      • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
      댓글 쓰기
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: 9 단계, 이미지 3개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: 9 단계, 이미지 3개 중 2개 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: 9 단계, 이미지 3개 중 3개
      • Remove the three screws from the center of the copper plate.
      • Remove the four screws from the outer edges of the copper plate.
      • Use a plastic or metal spudger to pry the copper plate out of place.
      댓글 쓰기
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 10 단계, 이미지 2개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the casing from the circuitboard by hand.
      • Remove the HDMI port casing by hand.
      댓글 쓰기
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: 11 단계, 이미지 3개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 11 단계, 이미지 3개 중 2개 Panasonic Lumix ZS50 Flash Assembly Replacement: 11 단계, 이미지 3개 중 3개
      • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
      • Disconnect the circuitboard by hand.
      • There will be one orange ribbon cable attached to the top that can now be removed.
      댓글 쓰기
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: 12 단계, 이미지 3개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 12 단계, 이미지 3개 중 2개 Panasonic Lumix ZS50 Flash Assembly Replacement: 12 단계, 이미지 3개 중 3개
      • Remove the seven screws surrounding the lens assembly.
      • Move all ribbon cables out of your way while unscrewing.
      • Remove the three springs surrounding the lens.
      • Apply pressure on the front of the lens to push the lens out.
      댓글 쓰기
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: 13 단계, 이미지 3개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: 13 단계, 이미지 3개 중 2개 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: 13 단계, 이미지 3개 중 3개
      • Remove the one screw holding the camera and the flash component together.
      • Gently pull the flash component out of the camera body.
      댓글 쓰기
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 14 단계, 이미지 3개 중 1개 Panasonic Lumix ZS50 Flash Assembly Replacement: 14 단계, 이미지 3개 중 2개 Panasonic Lumix ZS50 Flash Assembly Replacement: 14 단계, 이미지 3개 중 3개
      • Separate the top camera casing from the flash component by unscrewing the three surrounding screws.
      • Remove the flash assembly, including the circuit board, by detaching it and the ribbon cables from the casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Bridget Lathrop
회원 가입일: 02/01/17
158 평판
안내서 2개를 작성함
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 회원
BU-WHITNEY-S17S8G5
3 회원들
안내서 16개를 작성함
1가이드 댓글
Step 7: Does not mention the HDMI port door. Make sure you account for it
BayleeVersteeg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 64
전체 시간: 988
