주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic SA-HT810V DVD Drive Replacement
필요한 것
    1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: 1 단계, 이미지 3개 중 1개 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: 1 단계, 이미지 3개 중 2개 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: 1 단계, 이미지 3개 중 3개
      • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
      • Now rotate the device 180 degrees and remove the second screw.
      • Remove the screw that is on the right side of the panel facing you.
      • Remove all screws with a phillips head screwdriver.
      댓글 쓰기
    2. Panasonic SA-HT810V DVD Drive Replacement: 2 단계, 이미지 2개 중 1개 Panasonic SA-HT810V DVD Drive Replacement: 2 단계, 이미지 2개 중 2개
      • Rotate the device so that the back faces you.
      • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
      댓글 쓰기
    3. Panasonic SA-HT810V DVD Drive Replacement: 3 단계, 이미지 1개 중 1개
      • Before removing cover make sure that the back of the device is facing you.
      • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
      댓글 쓰기
    4. Panasonic SA-HT810V DVD Drive Replacement: 4 단계, 이미지 3개 중 1개 Panasonic SA-HT810V DVD Drive Replacement: 4 단계, 이미지 3개 중 2개 Panasonic SA-HT810V DVD Drive Replacement: 4 단계, 이미지 3개 중 3개
      • Pull up the two tabs on top
      • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
      • Depress the four tabs on the bottom of the device with a flat head screwdriver.
      댓글 쓰기
    5. Panasonic SA-HT810V DVD Drive Replacement: 5 단계, 이미지 1개 중 1개
      • Carefully pull off the front panel of the device.
      • The front is attached to the device with cables so be careful when removing.
      댓글 쓰기
    6. Panasonic SA-HT810V DVD Drive Replacement: 6 단계, 이미지 2개 중 1개 Panasonic SA-HT810V DVD Drive Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the four screws around the DVD drive with a phillips head screwdriver.
      댓글 쓰기
    7. Panasonic SA-HT810V DVD Drive Replacement: 7 단계, 이미지 1개 중 1개
      • The DVD player is attached to the power supply.
      • Remove the wire attaching it by firmly pulling on the wire until it releases.
      댓글 쓰기
    8. Panasonic SA-HT810V DVD Drive Replacement: 8 단계, 이미지 1개 중 1개
      • Flip the DVD drive so that the bottom is facing you.
      • Pull on the blue ribbon cable until it releases.
      • To place the new DVD drive in just follow these steps in reverse.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Nathan Cheadle
회원 가입일: 04/15/10
161 평판
안내서 7개를 작성함
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 회원
CPSU-MANESS-S10S16G5
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 38
전체 시간: 2,011
