주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic SC-PM31 Fan Replacement
필요한 것
    1. Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: 1 단계, 이미지 3개 중 1개 Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: 1 단계, 이미지 3개 중 2개 Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: 1 단계, 이미지 3개 중 3개
      • Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
      • Repeat the process for the opposite panel.
      • Remove the two 15 mm #2 Phillips screws from the back of the top panel.
      • Remove the middle 10mm #2 Phillips screw from the back of the top panel.
      댓글 쓰기
    2. Panasonic SC-PM31 Fan Replacement, Removing the panels: 2 단계, 이미지 2개 중 1개 Panasonic SC-PM31 Fan Replacement, Removing the panels: 2 단계, 이미지 2개 중 2개
      • If you do not have a plastic opening tool, you can open the system using your finger. However, if you choose to use your hands, make sure to wear gloves. The panel is very sharp.
      • Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
      댓글 쓰기
    3. Panasonic SC-PM31 Fan Replacement, Removing the white ribbon wire: 3 단계, 이미지 1개 중 1개
      • Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
      • The process will require the use of moderate force and can be eased by wiggling the ribbon during removal.
      댓글 쓰기
    4. Panasonic SC-PM31 Fan Replacement, Removing the top panel: 4 단계, 이미지 2개 중 1개 Panasonic SC-PM31 Fan Replacement, Removing the top panel: 4 단계, 이미지 2개 중 2개
      • Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
      • When reassembling the device, reattach the white ribbon wire (Step 3) before replacing the top panel.
      댓글 쓰기
    1. Panasonic SC-PM31 Fan Replacement, Removing the back panel screws: 5 단계, 이미지 1개 중 1개
      • Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
      댓글 쓰기
    2. Panasonic SC-PM31 Fan Replacement, Removing the back panel: 6 단계, 이미지 3개 중 1개 Panasonic SC-PM31 Fan Replacement, Removing the back panel: 6 단계, 이미지 3개 중 2개 Panasonic SC-PM31 Fan Replacement, Removing the back panel: 6 단계, 이미지 3개 중 3개
      • With a gentle tug, unplug the red and black cable from the tan circuit board.
      • Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other.
      • Slide the back panel toward you and off of the unit.
      댓글 쓰기
    1. Panasonic SC-PM31 Fan Replacement, Removing the fan.: 7 단계, 이미지 3개 중 1개 Panasonic SC-PM31 Fan Replacement, Removing the fan.: 7 단계, 이미지 3개 중 2개 Panasonic SC-PM31 Fan Replacement, Removing the fan.: 7 단계, 이미지 3개 중 3개
      • Flip the back panel over and locate the four clasps holding the fan in place.
      • One by one, unlock each clasp by pulling it outwards and gently lifting the fan up and away from it.
      • Remove the fan by lifting it gently away from the back panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Jessica Chao
회원 가입일: 09/29/14
650 평판
안내서 5개를 작성함
Cal Poly, Team 13-7, Forte Fall 2014 Cal Poly, Team 13-7, Forte Fall 2014 회원
CPSU-FORTE-F14S13G7
5 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 30
전체 시간: 1,524
