주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic SDR-H85 Hard Drive Replacement
필요한 것
    1. Panasonic SDR-H85 Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 Panasonic SDR-H85 Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 Panasonic SDR-H85 Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Gently slide the battery ejection button which is located underneath the battery and slide the battery out.
      • Once the battery is removed, you can safely dispose it and replace with a new one. Dispose battery at an authorized battery recycling center.
      댓글 쓰기
    1. Panasonic SDR-H85 Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1개 중 1개
      • Remove three Phillips #00 screws from the left-hand side of the camera.
      댓글 쓰기
    2. Panasonic SDR-H85 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
      • Flip the camera so the bottom is facing upwards.
      • Remove four Phillips #00 screws to release the bottom portion of the camera panel.
      댓글 쓰기
    3. Panasonic SDR-H85 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
      • Open up the charging port of the camera.
      • Hold the charging port flap open, and remove the single Phillips #00 screw.
      댓글 쓰기
    4. Panasonic SDR-H85 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
      • This step needs to be done very slowly and carefully due to the delicate hard drive ribbon cable.
      • Open the camera cover slowly and enough to see the orange ribbon cable. Do not pull to release the ribbon cable from the hard drive.
      • Gently detach the connection of the ribbon cable from the hard drive by using the spudger to drive a wedge between the ribbon cable and the hard drive itself.
      • Do not use excessive force on the ribbon cable due to its delicate nature. You should feel a click when the connection has been broken.
      댓글 쓰기
    5. Panasonic SDR-H85 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Panasonic SDR-H85 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Panasonic SDR-H85 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
      • Remove three Phillips #00 screws from the interior of the camera.
      • Carefully pull out the hard drive from both the top and the bottom in alternative moves, first from the top and then from the bottom.
      • Use slight force because the rubber lining around the hard drive is very secure.
      • Remove the rubber lining of the hard drive.
      • Make sure you remove the rubber lining carefully as it could pop through and potentially hit you.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Hamza Lodhi
회원 가입일: 01/14/20
381 평판
안내서 2개를 작성함
York University, Team S1-G8, Woodhouse Winter 2020 York University, Team S1-G8, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G8
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 34
전체 시간: 1,464
