주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement
필요한 것
  1. Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 1 단계, 이미지 3개 중 1개 Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 1 단계, 이미지 3개 중 2개 Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 1 단계, 이미지 3개 중 3개
    • Ensure your laptop is fully turned off. Flip it over so the bottom is facing up and the carry handle is facing away from you.
    • Remove the single 4 mm Phillips #00 screw holding the RAM access cover in place.
    • Gently rotate the cover upwards and pull it out. This will reveal the Toughbook’s RAM slots.
    댓글 쓰기
  2. Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement: 2 단계, 이미지 3개 중 1개 Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement: 2 단계, 이미지 3개 중 2개 Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement: 2 단계, 이미지 3개 중 3개
    • To unlock the RAM, gently pull both locking tabs apart.
    • Be careful in this step; any excessive force may snap the locking tabs off.
    • You will know that the RAM is unlocked when it rotates upwards.
    • Repeat this process for each stick you need to replace.
    댓글 쓰기
  3. Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement: 3 단계, 이미지 3개 중 1개 Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement: 3 단계, 이미지 3개 중 2개 Panasonic Toughbook CF-53 Random Access Memory (RAM) Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the RAM sticks from their slots.
    • If they require any amount of force to remove, ensure that both locking tabs have been unlocked.
    • When reassembling, slide your replacement sticks into the slot. Orient the gold contacts towards the slot. Ensure the plastic tab in the slot lines up with the cutout on the stick. Gently push down on each of the sticks until they lay flat above the motherboard. The two locking arms should audibly click into place when the stick is properly set.
    • Ensure that you are not forcing the stick into place as this may damage the RAM.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sean Marsden
회원 가입일: 09/16/19
688 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 43
전체 시간: 2,090
