주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Peavy 4 String Bass String Replacement
필요한 것
    1. Peavy 4 String Bass String Replacement, Strings: 1 단계, 이미지 1개 중 1개
      • Spin the pegs in the direction which loosens the string. Either unwind the string all the way and pull it out, or cut the string after loosening it a little.
      • Repeat for all the other strings.
      댓글 쓰기
    2. Peavy 4 String Bass String Replacement: 2 단계, 이미지 1개 중 1개
      • Now that you have a bass with no strings, grab your choice of bass strings, take them out of the bag and unwind them so they are straight.
      댓글 쓰기
    3. Peavy 4 String Bass String Replacement: 3 단계, 이미지 1개 중 1개
      • Pick up your ropes and arrange them in order from thickest to thinnest, sorting from bottom to top.
      댓글 쓰기
    4. Peavy 4 String Bass String Replacement: 4 단계, 이미지 1개 중 1개
      • Starting with the thickest string (E string), feed the string through the left-most hole at the base of the bridge (pictured left).
      • Repeat what you did with the E string with next thickest string (A string).
      • Repeat again for the next thinnest (D string), and again for the thinnest string (G string).
      댓글 쓰기
    5. Peavy 4 String Bass String Replacement: 5 단계, 이미지 1개 중 1개
      • Pull the strings all the way through so the pegs at the end of the strings are touching the bridge.
      댓글 쓰기
    6. Peavy 4 String Bass String Replacement: 6 단계, 이미지 1개 중 1개
      • Starting with the E string, make sure the string is in line with the correct notch on the nut.
      • Locate the hole in the guide and feed the string through the hole so it sticks out about one centimeter.
      • Rotate the tuning peg so that the string rotates counter-clockwise until the string is taut.
      • Repeat for the other 3 strings.
      댓글 쓰기
    7. Peavy 4 String Bass String Replacement: 7 단계, 이미지 1개 중 1개
      • Make sure the strings are wrapped around the peg in the correct direction as shown.
      • If any mistakes were made, you can always unwind the string and try it again.
      댓글 쓰기
      • Once all the strings are taut, begin tuning each string.
      • Now you have a bass with fresh strings!
      댓글 쓰기
결론
In order to get your bass sounding brand new again follow these steps and youll get a wonderful result
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Coby Anthony
회원 가입일: 02/05/19
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 30
전체 시간: 725
