주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pebble Steel Vibration Motor Replacement
필요한 것
  1. Pebble Steel Vibration Motor Replacement, Internal Hardware: 1 단계, 이미지 3개 중 1개 Pebble Steel Vibration Motor Replacement, Internal Hardware: 1 단계, 이미지 3개 중 2개 Pebble Steel Vibration Motor Replacement, Internal Hardware: 1 단계, 이미지 3개 중 3개
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
    댓글 쓰기
  2. Pebble Steel Vibration Motor Replacement: 2 단계, 이미지 2개 중 1개 Pebble Steel Vibration Motor Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
    댓글 쓰기
  3. Pebble Steel Vibration Motor Replacement, Vibration Motor: 3 단계, 이미지 1개 중 1개
    • Use a small plastic opening tool to remove the vibration motor from the motherboard.
    댓글 쓰기
  4. Pebble Steel Vibration Motor Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Orlandria Heggs
회원 가입일: 10/01/15
545 평판
안내서 3개를 작성함
USF Tampa, Team 1-7, Leahy Fall 2015 USF Tampa, Team 1-7, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G7
3 회원들
안내서 7개를 작성함
2가이드 댓글
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - 답글 공유
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 38
전체 시간: 3,852
