주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Pebble Time 수리는 자사의 서비스 설명서를 사용하세요.
    1. Pebble Time Teardown, Pebble Time Teardown: 1 단계, 이미지 2개 중 1개 Pebble Time Teardown, Pebble Time Teardown: 1 단계, 이미지 2개 중 2개
      • The official tech specs don't reveal much, but that's okay because we've got plenty of daylight to finish this teardown. Here's what we do know:
      • Low-power, 1.25-inch, 64-color, LED-backlit e-paper display
      • 6-axis inertial measurement unit, compass, ambient light sensor, microphone
      • Bluetooth 4.0
      • Lithium-ion polymer battery with a battery life of up to 7 days between charges
      • Apart from the e-paper display, what sort of technological whizbangery makes for 7-day battery life in a modern smartwatch? We're about to find out.
      댓글 쓰기
    2. Pebble Time Teardown: 2 단계, 이미지 3개 중 1개 Pebble Time Teardown: 2 단계, 이미지 3개 중 2개 Pebble Time Teardown: 2 단계, 이미지 3개 중 3개
      • The Pebble Time features a color e-paper display.
      • The back of the smartwatch is adorned with several markings, along with the port for the charging dock.
      • This feels like the first time we've seen a smartwatch that boasts a water resistance of 30 meters. Increased water resistance often means sacrificed repairability. Hopefully, Pebble has taken the time to work repairability into the equation.
      • That other watch, that we tore down a few weeks ago, seems to fare pretty well with water. It seems that Pebble is the only company with the stones to tout their 30 meter resistance outright.
      • The Time includes a proprietary USB charging cable with magnetic connectors (silver contact points) coupled with charging contact points (gold contacts).
      댓글 쓰기
    3. Pebble Time Teardown: 3 단계, 이미지 3개 중 1개 Pebble Time Teardown: 3 단계, 이미지 3개 중 2개 Pebble Time Teardown: 3 단계, 이미지 3개 중 3개
      • We're all about comparing apples and oranges, so we start off by seeing how the Time relates to another smartwatch we have laying around. This 38 mm Apple Watch Edition will have to suffice.
      • While they're roughly the same size, and serve somewhat similar functions, these displays take radically different approaches:
      • The minimalist, 144 x 168, 64-color, Gorilla Glass-topped e-paper screen on the Pebble stays on all the time—without compromising the battery.
      • On the other hand, the Apple Watch's touch-sensitive, sapphire-covered, 272 x 340 display is pretty, but also power hungry—so it spends most of its time switched off to conserve power.
      • Another immediately noticeable difference is in the weight. At 42.5 grams, the Time clocks in at well under half the heft of the 93-gram Apple Watch Edition.
      • Our hand model also notes that the Pebble's band feels a bit softer and more comfortable. Which is more durable? Only time will tell.
      • Did we mention there's a price difference? There's a price difference.
      댓글 쓰기
    4. Pebble Time Teardown: 4 단계, 이미지 3개 중 1개 Pebble Time Teardown: 4 단계, 이미지 3개 중 2개 Pebble Time Teardown: 4 단계, 이미지 3개 중 3개
      • Unlike the current batch of smartwatches on the market, the Pebble Time does not have a capacitive touch display. Instead, it relies on good ol' fashioned buttons (up, down, and select).
      • Bonus, the Pebble Time has a microphone!
      • Swapping bands is a breeze; simply pop the metallic pegs off the posts and swap. Pop and swap.
      • Customizers take note: The Time is compatible with a plethora of industry-standard 22 mm watch bands. Go wild.
      • With both bands out of the way, we proceed to remove the display with the help of our iOpener.
      댓글 쓰기
    5. Pebble Time Teardown: 5 단계, 이미지 3개 중 1개 Pebble Time Teardown: 5 단계, 이미지 3개 중 2개 Pebble Time Teardown: 5 단계, 이미지 3개 중 3개
      • With a minimum amount of heat applied to the front bezel, we use an opening pick to pry along the perimeter of the Pebble Time.
      • Open, uh, sarsaparilla? Uh, open Saskatchewan? Open, septuagenarian? Uh, open, saddle soap? Open, sesame! And with that, the front bezel (includes the glass) surprisingly separates from the Pebble Time.
      • Time after time, we've seen displays fused to a device's front glass—a process that makes for thin displays that are nearly impossible to repair. Good news everyone! The color e-paper display is NOT fused to the front glass.
      • Now that we've sliced open the waterproof seal, this Pebble won't be splashing around any time soon—although some say that very small rocks float in water.
      댓글 쓰기
    6. Pebble Time Teardown: 6 단계, 이미지 3개 중 1개 Pebble Time Teardown: 6 단계, 이미지 3개 중 2개 Pebble Time Teardown: 6 단계, 이미지 3개 중 3개
      • We use a spudger to lift the display from its housing and are momentarily reminded of the cable wrangling that we had to perform in a recent teardown.
      • No time for origami here. We're happy to see that the display cable is only folded in half once. We quickly spudger the display connector from the motherboard and move on to the battery connector. Wait, where is the battery connector?
      댓글 쓰기
    7. Pebble Time Teardown: 7 단계, 이미지 3개 중 1개 Pebble Time Teardown: 7 단계, 이미지 3개 중 2개 Pebble Time Teardown: 7 단계, 이미지 3개 중 3개
      • We go in for a closer look at the e-paper display, which in itself does a great job encapsulating the design choices and trade-offs of the Pebble Time.
      • With its comparatively limited color range (64 colors) and brightness, this display doesn't "pop" in the same way as some other smartwatch screens—but it has the distinct advantage of being always on, and of being fully visible in direct sunlight.
      • If you just want to know the time, it's there. No need to flick your wrist or squint at the display. However, there's also a manually-activated LED backlight, meaning there are still times when the display might be hard to read without a little brightness boost.
      • Pebble tells us this is a low-power, memory-in-pixel LCD. Through a microscope, we can see how the color trick is handled—different sized subpixels mix to create color.
      댓글 쓰기
    8. Pebble Time Teardown: 8 단계, 이미지 3개 중 1개 Pebble Time Teardown: 8 단계, 이미지 3개 중 2개 Pebble Time Teardown: 8 단계, 이미지 3개 중 3개
      • To remove the motherboard, we need to disconnect a couple connectors and take out four Phillips #00 screws.
      • A quick flick of the spudger painlessly frees the U-shaped motherboard.
      • No adhesives or soldered-on cables here.
      댓글 쓰기
    9. Pebble Time Teardown: 9 단계, 이미지 1개 중 1개
      • We've chipped away at this Pebble—now let's have a look at the motherboard. Front-side ICs include:
      • ST Micro STM32F439ZG 180 MHz ARM Cortex-M4-based MCU
      • Spansion S29VS128R 128 Mb, 65 nm MirrorBit Flash
      • Texas Instruments CC2564B Bluetooth and Dual-Mode Controller
      • Ambient light sensor
      댓글 쓰기
    10. Pebble Time Teardown: 10 단계, 이미지 1개 중 1개
      • More ICs adorning the back side:
      • Lattice LP1K Field Programmable Gate Array
      • +14690B EWXS 9.504 AB Power Management IC; likely Maxim Integrated's MAX14690EWX
      • Linear Tech LT3009 Linear Regulator (Pebble tells us that the LT3009 is included for supplying power to the upcoming Smartstraps)
      • Bosch Sensortec BMI160 (6-axis IMU with acceleroemeter and gyroscope)
      • Freescale Xtrinsic MAG3110 3D Digital Magnetometer
      • Texas Instruments DRV2603 Motor Driver
      • The blue arrow points to the smartstrap data in/out pin; above it in red is the power in/out pin and below it is the smartstrap/charging ground pin. The red arrow points to the positive (+) battery connector and next to it in black is the negative (-) connector.
      댓글 쓰기
    11. Pebble Time Teardown: 11 단계, 이미지 3개 중 1개 Pebble Time Teardown: 11 단계, 이미지 3개 중 2개 Pebble Time Teardown: 11 단계, 이미지 3개 중 3개
      • It's about time we got a clear view of the battery.
      • This 150 mAh, 0.57 Wh, 3.8 V battery packs a bit less punch than even the smallish 205 mAh, 0.78 Wh battery we found in the Apple Watch.
      • That's also about half the juice of other recent smartwatches, like the Moto 360 and the Samsung Gear Live—but with its e-paper display, Pebble claims that the Time can last up to seven days between charges.
      댓글 쓰기
    12. Pebble Time Teardown: 12 단계, 이미지 3개 중 1개 Pebble Time Teardown: 12 단계, 이미지 3개 중 2개 Pebble Time Teardown: 12 단계, 이미지 3개 중 3개
      • The microphone and vibrator assembly is next to be plucked out of (the) Time.
      • This is a Knowles microphone, waterproofed by a membrane behind the microphone port.
      • Since the Pebble is not compatible with Siri or Google Now, we asked Pebble what the microphone is going to be used for. They told us it's there for voice replies, and soon, voice notes. Neat!
      • We're all abuzz as we find the eccentric rotating mass vibrator soldered to the cable assembly, making replacement a tad bit more difficult.
      댓글 쓰기
    13. Pebble Time Teardown: 13 단계, 이미지 3개 중 1개 Pebble Time Teardown: 13 단계, 이미지 3개 중 2개 Pebble Time Teardown: 13 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • We're running out of things to pull from this Pebble's chassis. Those quality control markings prove difficult to grasp with our tweezers.
      • We asked and Pebble answered: these marks are confirmation that the rear case passed a water resistance inspection, which every rear case is subjected to before it gets to become a Time.
      • We manage to seize hold of this small c-clip securing the back button, which obligingly comes free for inspection.
      • The springy button is waterproofed by a small rubber o-ring.
      댓글 쓰기
    14. Pebble Time Teardown: 14 단계, 이미지 2개 중 1개 Pebble Time Teardown: 14 단계, 이미지 2개 중 2개
      • Pebble Time Repairability Score: 9 out of 10
      • The watch band is an industry standard 22 mm band with a quick release mechanism, meaning replacement bands will be easy to source and install.
      • The Pebble Time uses standard Phillips #00 screws inside, and once you're inside, components are fairly modular and very easy to remove.
      • The front glass and e-paper display are not fused together—the two components can be replaced independently, lowering repair cost.
      • Although the battery is tucked away under the motherboard, it is modular and removable.
      • Removing the front glass requires heat and replacement adhesive.
      댓글 쓰기
작성자
9다른 기여자 명과 함께
Ron Davis
회원 가입일: 02/17/15
33,661 평판
안내서 13개를 작성함
22가이드 댓글
so there is no additional RAM on the PCB? just the 256k of the MCU?
that is on one hand a bummer and on the other hand a great thing
the FPGA is possibly used for motion detection stuff and the display to keep the MCU asleep while processing the data for said devices.
DooMMasteR - 답글 공유
Good catch I missed that it has an FPGA and an ARM M4 on it. Wow. That is a freaking powerful combination!!!
RDustinB - 답글 공유
I would rather say that the M4 is for processing the Motion and handling data etc. and the FPGA is for driving the E-Ink Display. Personally, I dont see there any need for more RAM, as there isnt that much happening. Its rather just a Microcontroller on the board, like the Arduino, but more powerfull.
Matthias Nowak - 답글 공유
Thanks for the tear down iFixit dudes!
I feel like Pebble is the master at smartwatch development. This is a perfect culmination of part selection, design and execution. The battery life (even if it is normally only 60% of the maximum 7 days Pebble states) is fantastic and much easier for me to swallow than the "other" guys stating I'd need to charge my watch every single day.
Good job Pebble, you are doing it right.
RDustinB - 답글 공유
Can you teardown the Charging Cable for us? I have the new Pebble Time and the charging cable has already failed on me twice.
Benjamin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 100
전체 시간: 96,350
