주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax MX Front Board Removal
필요한 것
    1. Pentax MX Front Board Removal, Remove film advance lever: 1 단계, 이미지 3개 중 1개 Pentax MX Front Board Removal, Remove film advance lever: 1 단계, 이미지 3개 중 2개 Pentax MX Front Board Removal, Remove film advance lever: 1 단계, 이미지 3개 중 3개
      • Remove the lever cap. The cap is reverse threaded.
      • Lift off the advance lever.
      • Remove the collar beneath the lever.
      댓글 쓰기
    2. Pentax MX Front Board Removal, Remove shutter speed dial: 2 단계, 이미지 2개 중 1개 Pentax MX Front Board Removal, Remove shutter speed dial: 2 단계, 이미지 2개 중 2개
      • Set the ISO to 100 and the shutter speed to 1000.
      • Remove one pin head screw.
      • Lift off shutter speed dial.
      • Remove the collar beneath the dial.
      • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
      댓글 쓰기
    3. Pentax MX Front Board Removal, Remove rewind knob: 3 단계, 이미지 3개 중 1개 Pentax MX Front Board Removal, Remove rewind knob: 3 단계, 이미지 3개 중 2개 Pentax MX Front Board Removal, Remove rewind knob: 3 단계, 이미지 3개 중 3개
      • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
      • Remove the lock ring underneath the rewind knob.
      • Remove the cover plate.
      댓글 쓰기
    4. Pentax MX Front Board Removal, Remove top cover: 4 단계, 이미지 3개 중 1개 Pentax MX Front Board Removal, Remove top cover: 4 단계, 이미지 3개 중 2개 Pentax MX Front Board Removal, Remove top cover: 4 단계, 이미지 3개 중 3개
      • Remove two M1.7 x 3.2 mm screws.
      • Remove two M1.7 x 2 mm countersunk screws.
      • Lift off top cover.
      • The release cable pin in the shutter button is loose and may fall out.
      댓글 쓰기
    1. Pentax MX Front Board Removal, Remove front leatherette panels: 5 단계, 이미지 3개 중 1개 Pentax MX Front Board Removal, Remove front leatherette panels: 5 단계, 이미지 3개 중 2개 Pentax MX Front Board Removal, Remove front leatherette panels: 5 단계, 이미지 3개 중 3개
      • Apply isopropyl alcohol to soften the leatherette adhesive.
      • Turn the self-timer lever to the charged position.
      • Peel the leatherette off the camera body, carefully working it over the self-timer lever.
      • Remove one loose cover panel.
      • Repeat for the opposite panel.
      • Installation Notes: Clean all the old adhesive off of the camera body and leatherette panels before reapplying. Use contact cement to attach.
      댓글 쓰기
    2. Pentax MX Front Board Removal, Unsolder aperture resistor: 6 단계, 이미지 1개 중 1개
      • Unsolder two yellow wires for the aperture resistor.
      댓글 쓰기
    3. Pentax MX Front Board Removal, Remove front board: 7 단계, 이미지 3개 중 1개 Pentax MX Front Board Removal, Remove front board: 7 단계, 이미지 3개 중 2개 Pentax MX Front Board Removal, Remove front board: 7 단계, 이미지 3개 중 3개
      • Remove four M1.9 x 3.9 mm screws.
      • Lift off front board.
      • Look for shim washers at the screw locations and note their positions.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,444 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 41
전체 시간: 145
