주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax MX Viewfinder Speed Indication Adjustment
필요한 것
  1. Pentax MX Viewfinder Speed Indication Adjustment, Remove film advance lever: 1 단계, 이미지 3개 중 1개 Pentax MX Viewfinder Speed Indication Adjustment, Remove film advance lever: 1 단계, 이미지 3개 중 2개 Pentax MX Viewfinder Speed Indication Adjustment, Remove film advance lever: 1 단계, 이미지 3개 중 3개
    • Remove the lever cap. The cap is reverse threaded.
    • Lift off the advance lever.
    • Remove the collar beneath the lever.
    댓글 쓰기
  2. Pentax MX Viewfinder Speed Indication Adjustment, Remove shutter speed dial: 2 단계, 이미지 2개 중 1개 Pentax MX Viewfinder Speed Indication Adjustment, Remove shutter speed dial: 2 단계, 이미지 2개 중 2개
    • Set the ISO to 100 and the shutter speed to 1000.
    • Remove one pin head screw.
    • Lift off shutter speed dial.
    • Remove the collar beneath the dial.
    • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
    댓글 쓰기
  3. Pentax MX Viewfinder Speed Indication Adjustment, Remove rewind knob: 3 단계, 이미지 3개 중 1개 Pentax MX Viewfinder Speed Indication Adjustment, Remove rewind knob: 3 단계, 이미지 3개 중 2개 Pentax MX Viewfinder Speed Indication Adjustment, Remove rewind knob: 3 단계, 이미지 3개 중 3개
    • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
    • Remove the lock ring underneath the rewind knob.
    • Remove the cover plate.
    댓글 쓰기
  4. Pentax MX Viewfinder Speed Indication Adjustment, Remove top cover: 4 단계, 이미지 3개 중 1개 Pentax MX Viewfinder Speed Indication Adjustment, Remove top cover: 4 단계, 이미지 3개 중 2개 Pentax MX Viewfinder Speed Indication Adjustment, Remove top cover: 4 단계, 이미지 3개 중 3개
    • Remove two M1.7 x 3.2 mm screws.
    • Remove two M1.7 x 2 mm countersunk screws.
    • Lift off top cover.
    • The release cable pin in the shutter button is loose and may fall out.
    댓글 쓰기
  5. Pentax MX Viewfinder Speed Indication Adjustment, Detach viewfinder LED PCB: 5 단계, 이미지 2개 중 1개 Pentax MX Viewfinder Speed Indication Adjustment, Detach viewfinder LED PCB: 5 단계, 이미지 2개 중 2개
    • Remove one M1.3 x 2.8 mm screw and washer.
    • Remove one M1.7 x 2.8 mm screw.
    • Pull the LED PCB out of the side of the mirror box.
    • Installation Notes: Install batteries and check the position of the LEDs. Position the PCB as needed then tighten the screws to fix it in place.
    댓글 쓰기
  6. Pentax MX Viewfinder Speed Indication Adjustment, Install shutter speed dial: 6 단계, 이미지 1개 중 1개
    • Temporarily install the shutter speed dial.
    • Set the shutter speed to '1000'.
    • It can be helpful to tape the LED board out of the way while you work on the adjustment screws.
    댓글 쓰기
  7. Pentax MX Viewfinder Speed Indication Adjustment, Course adjustment: 7 단계, 이미지 3개 중 1개 Pentax MX Viewfinder Speed Indication Adjustment, Course adjustment: 7 단계, 이미지 3개 중 2개 Pentax MX Viewfinder Speed Indication Adjustment, Course adjustment: 7 단계, 이미지 3개 중 3개
    • You can skip this step if the speed indicator is close to the correct position in the viewfinder.
    • Loosen but do not remove the slotted post.
    • Shift the idler gear so that it doesn't engage with the gear attached to the speed display.
    • Move the disc until '1000' is displayed roughly between the two points on the edge of the frame.
    • Move the idler gear back into position so that it meshes with the gear attached to the speed display.
    • If the speed display does not move smoothly in both directions when the shutter dial is turned, adjust the eccentric until the gears mesh properly.
    • Tighten the lock screw.
    댓글 쓰기
  8. Pentax MX Viewfinder Speed Indication Adjustment, Fine adjustment: 8 단계, 이미지 1개 중 1개
    • Loosen the lock screw on the adjustment pulley. This screw is reverse threaded.
    • Turn the eccentric adjustment until '1000' is perfectly horizontal in the viewfinder.
    • Tighten the lock screw on the adjustment pulley.
    • Check the position of the indicators throughout the range of speeds. Repeat adjustment as necessary.
    댓글 쓰기
  9. Pentax MX Viewfinder Speed Indication Adjustment, Vertical adjustment: 9 단계, 이미지 1개 중 1개
    • Loosen two screws.
    • Move the support plate up or down to center the number vertically.
    • This adjustment will translate the indicator dial rather than rotate it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,384 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 105
전체 시간: 273
