주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax PZ-10 Back Cover Locking Switch Spring Replacement
필요한 것
    1. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Bottom Cover: 1 단계, 이미지 1개 중 1개
      • With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
      • Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
      • Pull off the bottom casing to remove.
      댓글 쓰기
    2. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing Bottom Casing: 2 단계, 이미지 1개 중 1개
      • With the screws removed, the bottom casing should come off very easily by pulling on the casing.
      댓글 쓰기
    3. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Back Cover: 3 단계, 이미지 1개 중 1개
      • Place the camera on its side so the lens is facing left.
      • Press down on the locking switch on the side panel facing you.
      댓글 쓰기
    4. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: 4 단계, 이미지 1개 중 1개
      • With the door unlocked, rotate the device to access the bottom.
      댓글 쓰기
    5. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using a pair of tweezers, gently remove the metal tab securing the back door axle.
      • The door will come loose at this point, watch for any loose parts that may also come out.
      댓글 쓰기
    6. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Side Panel: 6 단계, 이미지 1개 중 1개
      • Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
      댓글 쓰기
    7. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Spring: 7 단계, 이미지 1개 중 1개
      • Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
      • You are now ready to replace the spring.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Ryan Su
회원 가입일: 04/20/15
107 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 738
