주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax PZ-10 Button Replacement
필요한 것
    1. Pentax PZ-10 Button Replacement, Top Cover: 1 단계, 이미지 1개 중 1개
      • The top cover is one piece encasing the top of the device except the shutter release button and flash.
      댓글 쓰기
    2. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: 2 단계, 이미지 2개 중 1개 Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: 2 단계, 이미지 2개 중 2개
      • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
      • Using the J0 screwdriver, remove the 6.3 mm screw.
      댓글 쓰기
    3. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: 3 단계, 이미지 2개 중 1개 Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: 3 단계, 이미지 2개 중 2개
      • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
      • Remove the 6.3 mm screw using a J0 screwdriver.
      댓글 쓰기
    4. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: 4 단계, 이미지 2개 중 1개 Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: 4 단계, 이미지 2개 중 2개
      • The next screw is found in the overhanging piece just above the lens.
      • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
      댓글 쓰기
    5. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: 5 단계, 이미지 2개 중 1개 Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: 5 단계, 이미지 2개 중 2개
      • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
      댓글 쓰기
    1. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: 6 단계, 이미지 2개 중 1개 Pentax PZ-10 Button Replacement, Locate Rubber Tabs: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
      댓글 쓰기
    2. Pentax PZ-10 Button Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the 3 buttons by pushing them from under the casing out through the top.
      • Each button is slotted differently, so pay attention to the orientation of each piece.
      댓글 쓰기
    3. Pentax PZ-10 Button Replacement, Buttons: 8 단계, 이미지 1개 중 1개
      • The buttons are now free to be replaced or cleaned.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Jonathan Diaz
회원 가입일: 04/20/15
213 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 19
전체 시간: 847
