주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax Super Program Front Block Removal
필요한 것
    1. Pentax Super Program Front Block Removal, Remove film advance lever: 1 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Removal, Remove film advance lever: 1 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Removal, Remove film advance lever: 1 단계, 이미지 3개 중 3개
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      댓글 쓰기
    2. Pentax Super Program Front Block Removal, Remove mode dial: 2 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Remove mode dial: 2 단계, 이미지 2개 중 2개
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      댓글 쓰기
    3. Pentax Super Program Front Block Removal, Remove exposure compensation dial: 3 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Removal, Remove exposure compensation dial: 3 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Removal, Remove exposure compensation dial: 3 단계, 이미지 3개 중 3개
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      댓글 쓰기
    4. Pentax Super Program Front Block Removal, Remove top cover screws: 4 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Removal, Remove top cover screws: 4 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Removal, Remove top cover screws: 4 단계, 이미지 3개 중 3개
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      댓글 쓰기
    5. Pentax Super Program Front Block Removal, Remove top cover: 5 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Removal, Remove top cover: 5 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Removal, Remove top cover: 5 단계, 이미지 3개 중 3개
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      댓글 쓰기
    1. Pentax Super Program Front Block Removal, Remove bottom cover: 6 단계, 이미지 1개 중 1개
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      댓글 쓰기
    1. Pentax Super Program Front Block Removal, Remove front leatherette panels: 7 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Removal, Remove front leatherette panels: 7 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Removal, Remove front leatherette panels: 7 단계, 이미지 3개 중 3개
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      댓글 쓰기
    2. Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: 8 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: 8 단계, 이미지 2개 중 2개
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      댓글 쓰기
    3. Pentax Super Program Front Block Removal, Unsolder motor drive connections: 9 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Unsolder motor drive connections: 9 단계, 이미지 2개 중 2개
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      댓글 쓰기
    4. Pentax Super Program Front Block Removal, Remove tripod mount: 10 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Remove tripod mount: 10 단계, 이미지 2개 중 2개
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      댓글 쓰기
    5. Pentax Super Program Front Block Removal, Detach ISO resistor assembly: 11 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Detach ISO resistor assembly: 11 단계, 이미지 2개 중 2개
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      댓글 쓰기
    6. Pentax Super Program Front Block Removal, Detach mode dial unit: 12 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Removal, Detach mode dial unit: 12 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Removal, Detach mode dial unit: 12 단계, 이미지 3개 중 3개
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      댓글 쓰기
    7. Pentax Super Program Front Block Removal, Unsolder flash sync wires: 13 단계, 이미지 1개 중 1개
      • Unsolder two gray wires.
      댓글 쓰기
    8. Pentax Super Program Front Block Removal, Unsolder shutter wires: 14 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Unsolder shutter wires: 14 단계, 이미지 2개 중 2개
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      댓글 쓰기
    9. Pentax Super Program Front Block Removal, Unscrew mirror box: 15 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Unscrew mirror box: 15 단계, 이미지 2개 중 2개
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      댓글 쓰기
    10. Pentax Super Program Front Block Removal, Unscrew front board: 16 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Removal, Unscrew front board: 16 단계, 이미지 2개 중 2개
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      댓글 쓰기
    11. Pentax Super Program Front Block Removal, Remove mirror box and front board: 17 단계, 이미지 1개 중 1개
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      댓글 쓰기
    12. Pentax Super Program Front Block Removal, Installation Notes: Front Block: 18 단계, 이미지 1개 중 1개
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,444 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 33
전체 시간: 391
