주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax Super Program Mirror Box Mechanism Service
필요한 것
    1. Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: 1 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: 1 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: 1 단계, 이미지 3개 중 3개
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      댓글 쓰기
    2. Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: 2 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: 2 단계, 이미지 2개 중 2개
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      댓글 쓰기
    3. Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: 3 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: 3 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: 3 단계, 이미지 3개 중 3개
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      댓글 쓰기
    4. Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: 4 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: 4 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: 4 단계, 이미지 3개 중 3개
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      댓글 쓰기
    5. Pentax Super Program Mirror Box Mechanism Service, Remove top cover: 5 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: 5 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: 5 단계, 이미지 3개 중 3개
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      댓글 쓰기
    1. Pentax Super Program Mirror Box Mechanism Service, Remove bottom cover: 6 단계, 이미지 1개 중 1개
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      댓글 쓰기
    1. Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: 7 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: 7 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: 7 단계, 이미지 3개 중 3개
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      댓글 쓰기
    2. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: 8 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: 8 단계, 이미지 2개 중 2개
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      댓글 쓰기
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: 9 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: 9 단계, 이미지 2개 중 2개
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      댓글 쓰기
    4. Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: 10 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: 10 단계, 이미지 2개 중 2개
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      댓글 쓰기
    5. Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: 11 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: 11 단계, 이미지 2개 중 2개
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      댓글 쓰기
    6. Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: 12 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: 12 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: 12 단계, 이미지 3개 중 3개
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      댓글 쓰기
    7. Pentax Super Program Mirror Box Mechanism Service, Unsolder flash sync wires: 13 단계, 이미지 1개 중 1개
      • Unsolder two gray wires.
      댓글 쓰기
    8. Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: 14 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: 14 단계, 이미지 2개 중 2개
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      댓글 쓰기
    9. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 15 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 15 단계, 이미지 2개 중 2개
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      댓글 쓰기
    10. Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: 16 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: 16 단계, 이미지 2개 중 2개
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      댓글 쓰기
    11. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box and front board: 17 단계, 이미지 1개 중 1개
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      댓글 쓰기
    12. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Front Block: 18 단계, 이미지 1개 중 1개
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      댓글 쓰기
    1. Pentax Super Program Mirror Box Mechanism Service, Unsolder Main PCB: 19 단계, 이미지 1개 중 1개
      • Unsolder one orange and one blue wire for the mirror release solenoid.
      • Unsolder one pink wire for the LCD backlight.
      • Unsolder two purple wires for the TL switch.
      • Unsolder one green wire for the MD switch.
      댓글 쓰기
    2. Pentax Super Program Mirror Box Mechanism Service, Unsolder lens mount connections (early production): 20 단계, 이미지 1개 중 1개
      • Unsolder six wires for the lens mount pin connections.
      • These are only present on the early production models. Later production models moved these connection points to the flex connector.
      댓글 쓰기
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: 21 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: 21 단계, 이미지 2개 중 2개
      • Unsolder two yellow wires for the aperture resistor.
      댓글 쓰기
    4. Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: 22 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: 22 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: 22 단계, 이미지 3개 중 3개
      • Unsolder the red and black wires for the metering cells in the eye piece.
      • Unsolder pink and green wires for the flash sync connections.
      댓글 쓰기
    5. Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): 23 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): 23 단계, 이미지 2개 중 2개
      • Unsolder blue and black wires for self-timer LED.
      • Unsolder orange wire for beeper.
      • Unsolder gray and pink wires for aperture solenoid.
      • Unsolder light blue and yellow wires for aperture optical encoder.
      • Unsolder purple wire for self-timer contact.
      • Remove one screw.
      댓글 쓰기
    6. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): 24 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): 24 단계, 이미지 2개 중 2개
      • Remove two M1.4 x 2 mm screws.
      • Use a spudger to gently pry off the connector plate.
      • Remove the silicone insulating pad.
      댓글 쓰기
    7. Pentax Super Program Mirror Box Mechanism Service, Detach viewfinder LCD: 25 단계, 이미지 1개 중 1개
      • Remove two M1.4 x 1.6 mm screws.
      • Look for shim washers when removing and note their position.
      댓글 쓰기
    8. Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: 26 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: 26 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: 26 단계, 이미지 3개 중 3개
      • Loosen one M1.7 x 4.5 mm screw but leave it in place.
      • Remove two M1.7 x 1.6 mm screws.
      • Remove the mirror governor.
      • Remove one plastic bushing.
      댓글 쓰기
    9. Pentax Super Program Mirror Box Mechanism Service, Remove main PCB: 27 단계, 이미지 1개 중 1개
      • Gently lift away the PCB from the mirror box.
      • The TTL flash metering cell needs to be unseated from the side of the mirror box to free the PCB for removal.
      댓글 쓰기
    1. Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: 28 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: 28 단계, 이미지 2개 중 2개
      • Lift flex PCB off of mounting posts.
      • Remove silicone insulator pad.
      댓글 쓰기
    2. Pentax Super Program Mirror Box Mechanism Service, Remove beeper: 29 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove beeper: 29 단계, 이미지 2개 중 2개
      • Remove one screw and retainer plate.
      • Remove beeper.
      댓글 쓰기
    3. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 30 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 30 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 30 단계, 이미지 3개 중 3개
      • Remove two M2 x 3 mm screws.
      • Remove one M1.7 x 3 mm screw.
      • Charge and release the mirror so it is in the taking position (up against the focusing screen).
      댓글 쓰기
    4. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box: 31 단계, 이미지 1개 중 1개
      • Lift mirror box away from front lens board.
      댓글 쓰기
    5. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: 32 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: 32 단계, 이미지 2개 중 2개
      • Check the following coupling points between the front lens board and the mirror box.
      • Aperture control.
      • Self-timer lever is above the mirror release latch.
      • Depth of field preview lever.
      댓글 쓰기
      • Insert wisdom here.
      댓글 쓰기
    1. Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: 34 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: 34 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: 34 단계, 이미지 3개 중 3개
      • Remove one M1.3 x 2.1 mm shoulder screw.
      • Remove one M1.3 x 2.4 mm screw.
      • Remove coil spring.
      • Note the rubber bumper on the pivot post. This should be removed and cleaned before reassembly.
      댓글 쓰기
    2. Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: 35 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: 35 단계, 이미지 2개 중 2개
      • Remove one M1.5 x 3.5 mm screw.
      • Remove the bias spring.
      • Remove the brass bushing.
      댓글 쓰기
    3. Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: 36 단계, 이미지 3개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: 36 단계, 이미지 3개 중 2개 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: 36 단계, 이미지 3개 중 3개
      • Unhook and remove the coil spring. It may be tacked in place with lacquer.
      • Remove one M1.3 x 4.5 mm screw.
      • Remove the depth of field preview lever.
      • Remove the bushing.
      댓글 쓰기
    4. Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: 37 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: 37 단계, 이미지 2개 중 2개
      • Use a spanner wrench or u-bit to remove two nuts.
      • Lift off auto-aperture control lever.
      댓글 쓰기
    5. Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: 38 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: 38 단계, 이미지 2개 중 2개
      • Lift off mirror flip-up lever.
      • Remove shim washer.
      • Remove plastic bushing.
      댓글 쓰기
    6. Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: 39 단계, 이미지 2개 중 1개 Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: 39 단계, 이미지 2개 중 2개
      • Remove aperture stop-down lever.
      • Installation Notes: Ensure the lever foot is placed properly between the mirror flip-up spring and the mirror return lever during reassembly.
      댓글 쓰기
    7. Pentax Super Program Mirror Box Mechanism Service, Clean mirror box components: 40 단계, 이미지 1개 중 1개
      • Remove two old rubber bumpers.
      • Clean all pivots with isopropyl alcohol.
      • Clean all removed components with isopropyl alcohol.
      댓글 쓰기
    8. Pentax Super Program Mirror Box Mechanism Service, Reassembly Notes: 41 단계, 이미지 1개 중 1개
      • The mirror mechanism does not need lubrication to operate properly. Most moving interfaces run dry.
      • High friction latching points can be lubricated with a heavy moly grease to reduce wear.
      • Replacement rubber dampers are optional. Silicone tubing cut to length is good source.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,444 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 19
지난 30일: 56
전체 시간: 565
