주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax Super Program Shutter Service
필요한 것
  1. Pentax Super Program Shutter Service, Remove film advance lever: 1 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Remove film advance lever: 1 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Remove film advance lever: 1 단계, 이미지 3개 중 3개
    • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
    • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
    • Lift off the advance lever.
    • Remove the spring washer.
    • Remove one shim washer.
    댓글 쓰기
  2. Pentax Super Program Shutter Service, Remove mode dial: 2 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Remove mode dial: 2 단계, 이미지 2개 중 2개
    • Set the mode dial to the 'L' position.
    • Use a spanner wrench to unscrew the dial lock nut.
    • Lift off the mode dial.
    댓글 쓰기
  3. Pentax Super Program Shutter Service, Remove exposure compensation dial: 3 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Remove exposure compensation dial: 3 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Remove exposure compensation dial: 3 단계, 이미지 3개 중 3개
    • Place a rigid object in the fork.
    • Unscrew the rewind lever.
    • Use a spanner wrench to remove the lock nut.
    • Lift off the exposure compensation dial.
    댓글 쓰기
  4. Pentax Super Program Shutter Service, Remove top cover screws: 4 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Remove top cover screws: 4 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Remove top cover screws: 4 단계, 이미지 3개 중 3개
    • Remove two screws on either side of the eye piece.
    • Remove two screws on either side of the lens mount.
    댓글 쓰기
  5. Pentax Super Program Shutter Service, Remove top cover: 5 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Remove top cover: 5 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Remove top cover: 5 단계, 이미지 3개 중 3개
    • Remove one screw by the exposure compensation dial.
    • Use a spanner wrench to remove the lock nut under the advance lever.
    • Lift off the top cover slowly. It is still attached by one wire.
    • Unsolder one gray flash sync wire.
    댓글 쓰기
  6. Pentax Super Program Shutter Service, Remove bottom cover: 6 단계, 이미지 1개 중 1개
    • Remove three M1.7 x 3 mm screws.
    • Remove bottom cover.
    댓글 쓰기
  7. Pentax Super Program Shutter Service, Remove front leatherette panels: 7 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Remove front leatherette panels: 7 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Remove front leatherette panels: 7 단계, 이미지 3개 중 3개
    • Use a nickel or other large coin to remove the hand grip.
    • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
    • Use a dull scraper to lift one corner and pull off the panel.
    • Repeat on the rewind side of the camera.
    • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
    댓글 쓰기
  8. Pentax Super Program Shutter Service, Detach flex PCB with adjustment pots: 8 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Detach flex PCB with adjustment pots: 8 단계, 이미지 2개 중 2개
    • Remove one M1.7 x 4.5 mm screw.
    • Remove one slotted screw.
    • Use isopropyl alcohol to soften the adhesive under the flex PCB.
    • Gently lift the PCB until it is free from the camera body.
    댓글 쓰기
  9. Pentax Super Program Shutter Service, Unsolder motor drive connections: 9 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Unsolder motor drive connections: 9 단계, 이미지 2개 중 2개
    • Unsolder red wire for positive battery.
    • Unsolder green wire.
    • Unsolder orange wire for motor drive shutter release.
    • Unsolder purple wire for wind completion switch.
    댓글 쓰기
  10. Pentax Super Program Shutter Service, Remove tripod mount: 10 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Remove tripod mount: 10 단계, 이미지 2개 중 2개
    • Remove one M1.7 x 5 mm screw.
    • Remove one countersunk M1.7 x 5.5 mm screw.
    • Lift the contact terminal free from its seat.
    • Remove the tripod mount.
    댓글 쓰기
  11. Pentax Super Program Shutter Service, Detach ISO resistor assembly: 11 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Detach ISO resistor assembly: 11 단계, 이미지 2개 중 2개
    • Remove one M1.7 x 4 mm screw.
    • Loosen one slotted screw (this will remain connected to the assembly).
    • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
    댓글 쓰기
  12. Pentax Super Program Shutter Service, Detach mode dial unit: 12 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Detach mode dial unit: 12 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Detach mode dial unit: 12 단계, 이미지 3개 중 3개
    • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
    • Lift the LCD out of the way. It is still attached by a flex PCB.
    • Remove one slotted post.
    댓글 쓰기
  13. Pentax Super Program Shutter Service, Unsolder flash sync wires: 13 단계, 이미지 1개 중 1개
    • Unsolder two gray wires.
    댓글 쓰기
  14. Pentax Super Program Shutter Service, Unsolder shutter wires: 14 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Unsolder shutter wires: 14 단계, 이미지 2개 중 2개
    • Unsolder white wire.
    • Unsolder brown wire.
    • Unsolder red wire.
    댓글 쓰기
  15. Pentax Super Program Shutter Service, Unscrew mirror box: 15 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Unscrew mirror box: 15 단계, 이미지 2개 중 2개
    • Remove two M1.7 x 2.5 mm screws.
    • Remove one M1.7 x 3.5 mm screw under the bottom plate.
    • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
    댓글 쓰기
  16. Pentax Super Program Shutter Service, Unscrew front board: 16 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Unscrew front board: 16 단계, 이미지 2개 중 2개
    • Wind the advance lever to put the shutter and mirror box in the charged state.
    • Remove four M1.9 x 5 mm screws.
    댓글 쓰기
  17. Pentax Super Program Shutter Service, Remove mirror box and front board: 17 단계, 이미지 1개 중 1개
    • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
    • Wiggle the mirror box and front board free.
    • Watch for wire snags as you pull it free.
    • Check for loose shim washers on the front board and note their position.
    댓글 쓰기
  18. Pentax Super Program Shutter Service, Installation Notes: Front Block: 18 단계, 이미지 1개 중 1개
    • Shutter should be in the charged state.
    • Mirror box should be in released state.
    • Pay close attention to wire routing during install.
    • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
    댓글 쓰기
  19. Pentax Super Program Shutter Service, Remove shutter unit: 19 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Remove shutter unit: 19 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Remove shutter unit: 19 단계, 이미지 3개 중 3개
    • Lift shutter unit out of camera body.
    댓글 쓰기
  20. Pentax Super Program Shutter Service, Release the shutter: 20 단계, 이미지 1개 중 1개
    • Push the shutter release latch down to fire the shutter.
    • Reducing the tension of the shutter springs makes disassembly and reassembly easier.
    댓글 쓰기
  21. Pentax Super Program Shutter Service, Remove rear plate: 21 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Remove rear plate: 21 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Remove rear plate: 21 단계, 이미지 3개 중 3개
    • Remove old foam seals.
    • Foam seals should be replaced with new material during reassembly.
    • Remove four M1.4 x 2.4 mm screws.
    • Remove top spacer bushing.
    댓글 쓰기
  22. Pentax Super Program Shutter Service, Remove closing curtain: 22 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Remove closing curtain: 22 단계, 이미지 2개 중 2개
    • Remove closing curtain linkage.
    • Remove five curtain blades.
    • Installation Notes: Make sure the helper spring is properly hooked on the closing curtain linkage when reassembled.
    댓글 쓰기
  23. Pentax Super Program Shutter Service, Remove curtain separator: 23 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Remove curtain separator: 23 단계, 이미지 2개 중 2개
    • Remove curtain separator.
    • Remove lower separator bushing.
    댓글 쓰기
  24. Pentax Super Program Shutter Service, Remove opening curtain: 24 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Service, Remove opening curtain: 24 단계, 이미지 2개 중 2개
    • Remove three curtain blades.
    • Remove opening curtain linkage.
    댓글 쓰기
  25. Pentax Super Program Shutter Service, Clean the shutter: 25 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Service, Clean the shutter: 25 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Service, Clean the shutter: 25 단계, 이미지 3개 중 3개
    • Remove two curtain guides.
    • Clean any residue from the shutter frame and blades using isopropyl alcohol or other solvent.
    • Clean the curtain pivots.
    • Remove degraded rubber dampers and clean the surrounding area. They do not need to be replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
11,000 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 52
전체 시간: 577
